Code help
Code help
Hey guys. So....
On my way home, im doing about 60 mph, go to shift my 07 ss/sc from 4th gear into 5th, and I missed 5th gear, slammed my gas pedal apparently, and yeah slammed the Red line.
Instantly "Reduced Engine Power" comes on and from this point on, the car does not start
Did i blow up my throttle? lol
I have a SnapOn code scanner...it shows these codes:
P0116: Coolant Temperature Curcuit Out Of Range
P0111: Intake Air Temperature Curcuit Out of Range
P0443: EVAP Purge Control Curcuit Fault
P0532 A/C Pressure Sensor Circuit Signal Low
P1516: Electronic Throttle Mod VS Throttle Position Performance
P2119: Throttle Closed Position Performance
I know it has to do with the last 2 codes i listed. I know with only the codes its hard to tell EXACTLY what it could be....but im hoping someone can imagine what would have broke after me going to shift gear(a bit violently lol) and missing 5th and just slamming the gas pedal in Neutral basically.
ANY HELP IS SUPER APPRECIATED!!!!
id try clearing the codes and see if it starts. diagnose it from there. often doing something like you did will confuse the computer as it has no idea what to do, and codes are set.
The codes look like the TPS is out of adjustment. You may have messed up the TPS reading when it slammed open or you could have messed up the throttle plate. I would try clearing the codes like Sharkey suggested and see if it will start. If the car still won't run and the codes come right back then you may need a new throttle body.
boost_junkie16
Apr 11, 2016 07:08 AM
tvpthemvp93
Apr 5, 2016 08:59 PM
