Cold Air Intake = CEL?
Old Sep 26, 2010 | 11:36 PM
AzraelRaezier's Avatar
so yesterday i removed my stock intake a put on my Injen Cold Air intake and my check engine light went off.... then today it came back on. not sure why... any ideas? i read something someone posted about getting bigger injectors? help plz
Old Sep 26, 2010 | 11:40 PM
IamtheCobaltian's Avatar
Your supposed to disconnect the battery before putting it on so that when you connect the battery again it recalibrates and the computer recognizes that its there.
Old Sep 27, 2010 | 01:26 AM
i did disconnect the negative terminal on the battery.
Old Sep 27, 2010 | 01:32 AM
ecot3c inside's Avatar
no aftermarket intakes almost always throw a code, I for one just disabled it (it's the magic of a senior member grasshoppers)
Old Sep 27, 2010 | 01:41 AM
redcobalt07's Avatar
what code is it? are you running a breather filter?
Old Sep 27, 2010 | 01:55 AM
dont know the code. havent hit up autozone to check it yet. i used to throw a code for something. dont remember what it was. i used to have a problem with my engine not wanting to stay started after filling my tank with gasoline? dumb i know. and every once and a while when i started it cold it would bounce between 500-1000rpms like it was going to stall. just got the itnake yesterday. havent refilled or had any issues yet just the CEL.
Old Sep 27, 2010 | 01:56 AM
also. in regaurds to the stalling after filling. it was ONLY after putting gas in the tank id have issues. but if i revved the engine right as it turned over. it would stay on fine. but if i tried starting it right after filling it without reving. it would choke out and die. on the second start it would run fine.
Old Sep 27, 2010 | 01:57 AM
i dont know what a"breather filter" is. im running an injen filter. the one that Came with the intake
Old Sep 27, 2010 | 02:07 AM
06arrivalSC's Avatar
? Not sure what you mean by this, but the computer doesnt 'recognize' that there is suddenly a new intake there in a sense that it will now magically adjust for a new CAI...what it does recognize is that there is now more airflow than its supposed to see based on the stock tune or whatever tune you have on and it starts altering your fuel trims to try to compensate for the now changed MAF readings from what its used to seeing. This is why alot of intakes will cause you to throw codes because the PCM is not tuned for the intake so it goes **** and throws a code. You have to tune for an intake or you wont see gains really, and its actually not really good for the car to go untuned with an intake.
Go to this link
https://www.cobaltss.net/forums/08-0...ng-car-225160/
He explains it quite well
What kind of setup do you have? List all your mods i guess is what i mean lol
EDIT: Nvm i see your mods in your sig...i dont think the 2.2s are tuneable either...
Old Sep 27, 2010 | 03:14 AM
guess ill just let it go for now. im not really too concerned with it. im not planning on having the car for very much longer and i have the stock intake still. i do notice some preformance gains even with out the tune. im going to go talk to sublime speed technology tomorrow and see if there is tuning available for my car and see what the reccomend with the new upgrade.
turbochargedss2012
Sep 20, 2023 12:17 PM
no_ss
Oct 18, 2015 11:58 PM
z28addiction
Sep 28, 2015 12:03 AM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
