Coolant Problem
Old Jul 13, 2016 | 12:42 PM
geofery_sousa's Avatar
Coolant Problem
Alright so I've had my car for a few months and noticed that it keeps saying low coolant. i realized that I'm losing coolant from the spot right behind the radiator not the reservoir tank. Now i don't think its a leak because I never see any spots on the ground. unfortunately i have to refill it about every 100 miles or so. I really have no idea what the problem is anyone have any ideas?
Old Jul 13, 2016 | 01:53 PM
exninja's Avatar
I'm confused, you narrowed the leak down to the radiator, but you don't know where it is?
Old Jul 13, 2016 | 08:53 PM
T-fog's Avatar
^^This you need to explain why you think there is a leak behind the rad.
We also need spec of the car.... Year,model and/or engine size, So we can help.
Old Jul 19, 2016 | 01:11 PM
06 cobalt 2.0L 4cylinder supercharged. Im not actually sure where the leak is coming from because I cant see it leaking. So I have tto different spots to put in coolant. A reservoir tank up by the drivers side and right behind the radiator. Now the tank is never empty however the other spot usually looks like its going empty but when I put pressure on the hose i can still feel coolant in there. Now the engine never runs hotter than normal but the low coolant sensor is always on.
Old Jul 19, 2016 | 01:30 PM
double clutch's Avatar
The one in the front of the car has nothing to do with your engine cooling system and will not effect the temp or cause the light to set. That is for your intercooler and it will periodically need to be filled. Shitty design. It can be fixed by getting option b
Old Jul 19, 2016 | 06:09 PM
ItalianJoe1's Avatar
Not really. If the pump is working well it doesn't boil out and lose coolant. If you're adding fluid to your intercooler circuit it's a good indication that your pump is dying.
OP, if you can, take a picture of where on the car you see the leak coming from and post it here, it will help us out.
If you're adding coolant to the bottle on the drivers side fender, then yes that's engine coolant and the one that triggers the "low coolant" warning on your dash.
There's not much to leak in the front besides the radiator, odds are it's damaged or has the end tank cracking/leaking, if you see coolant under the front of the car. There's just two hoses going to it, the upper one over the supercharger and the lower over the transmission on the other side. Should be fairly easy to see where it's leaking as coolant always leaves a residue stain where it dries up.
Old Jul 20, 2016 | 11:42 AM
Yeah Im not seeing any coolant under the car. Also the actually tank itself doesnt need to be refilled. Could it just possibly be a bad coolant sensor than if it keeps popping up? Also I dont know a whole lot about intercoolers would it be difficult to replace the pump?
Old Jul 20, 2016 | 04:39 PM
Even with a new pump i always had to fill up every few weeks. I brought it up to josh at ottp and he told me it was normal. He said its a crap design pretty much
Old Jul 20, 2016 | 04:48 PM
06blackg85ss's Avatar
if the coolant in the actual res isn't low (driverside by fuse block) and the message comes on the sensor is probably shot. mines been dead for about 2 years now, low coolant always comes on when I start the car up
Manny munos
Nov 29, 2016 06:32 PM
CudaJoe
40
Aug 16, 2016 12:52 AM
PyroMechanic
Aug 1, 2016 10:41 PM
Studer
Jul 12, 2016 03:16 PM
Jamie1234567
Jun 22, 2016 11:51 PM
