Coolant Temp Bouncing
Old May 26, 2012 | 11:15 PM
Murdered SS's Avatar
I have an 06 ss\sc just installed OTTP H\E i just want to double check i installed correctly. So the top hose goes hooked up with the out hose of the stock h\e and the bottom hose goes hooked up with the top or in of the ic pump correct? I dont have a dual pass yet or option b. I'm just wondering cause i've been driving around today watch my coolant temp bounce around. Usually it stays around 183 or so today it was going over that. also whats the correct way to flush and fill the whole system? Any help would be greatlly appreciated thanks in advance.
Old May 26, 2012 | 11:25 PM
06cobalt racer's Avatar
the coolant system for the supercharger is completely different then the system for the engine. the temp gauge on the dash is for the engine. there isnt a sensor in the supercharger system for coolant temp.
Old May 26, 2012 | 11:32 PM
I see but my coolant temp has changed alot since i installed my H\E yesterday. So what could be causing the drastic change?
Old May 27, 2012 | 12:02 AM
Old May 27, 2012 | 12:18 AM
EmperorJJ1's Avatar
what was the temp outside yesterday compared to today?
Old May 27, 2012 | 12:34 AM
today was cooler than yesterday. I live in vegas so it get really hot here its still cool here in about a month its gonna get really hot about 3 digits hot. So i want to get this handled asap.
Old May 27, 2012 | 05:45 AM
how much is it bouncing around? and how quick?
Old May 27, 2012 | 08:15 AM
Edubs's Avatar
It's probably just an airflow issue. Your new H/E is now blocking flow to your radiator. This is why the most efficient recommendation is to replace the stock H/E with a griffin unit...
Old May 27, 2012 | 08:56 AM
insylem's Avatar
There is on my car
Old May 27, 2012 | 11:47 AM
not really. the OTTP HE doesnt really cover the radiator in our cars
Originally Posted by insylem
There is on my car
well arent you just so special!!!! ha ha ha
Old May 27, 2012 | 11:49 AM
insylem's Avatar
Talking
Yes I am
I needed soemthing to plug the drain hole in OTTP's H/E so I got an adaptor and pluged it with a fluid temp sensor that I ran to my Analogic Gauge
I Love my gauges
Old May 27, 2012 | 11:56 AM
Yes I am
I Love my gauges
thats a good idea. i have ZZP S3 though so no drain plug for me.
Old May 27, 2012 | 12:15 PM
05Slowline's Avatar
as long as it doesn't start going over 230+ it's fine. if you're that worried, get hptuned and command the fans to be on all the time.
Old May 27, 2012 | 12:56 PM
Edubs's Avatar
Where does the OTTP H/E get it's airflow from? Where does the radiator get it's airflow from?
Old May 27, 2012 | 02:05 PM
insylem's Avatar
Ram air when your moving forward
The Radiator Fans when your stopped
Ram air when moving forward
Old May 27, 2012 | 02:07 PM
what i was saying is that the HE doesnt cover the radiator all that much. just a little on the bottom of it. the HE gets its air through the lower opening...radiator mostly through the upper grill.
Old May 27, 2012 | 03:15 PM
thanks for the in input guys really appreciated. So it bounces pretty good today i went to work which is mostly highway so it stayed at about 178 to 180 pretty steady then after i got off the freeway it started to go up to like 196 around there. When driving it would go doen a bit but not much. Also whats the correct way to flush and fill system? Thanks to all of your help very much appreciated.
Old May 27, 2012 | 03:24 PM
05Slowline's Avatar
that is normal temps dude
Old May 27, 2012 | 03:43 PM
insylem's Avatar
Ya those are normal temps,
Also remember your engine is working harder to keep you at cruise then it is idleing at a stoplight....
BUT.. you have more airflow at cruise so your temps will be lower, when you stop, your temp well go up since you just lost your cooling air, Once temps reach a cetin point determined by your tuen (I think 223 to 230 degrees) your fans will start to come on, slow at first then faster giveing you back your cooling air.
Old May 27, 2012 | 06:22 PM
Ok coo thanks guys i just wanted to make sure so i dont f my car up. So whats the correct way to flush and fill the H\e?
Old May 27, 2012 | 07:02 PM
05Slowline's Avatar
easiest way is opt b takes like 3 mins cause it'll bleed the air by itself. without option b you'll have to fill, drive, fill drive, etc.
Old May 27, 2012 | 07:50 PM
or make a custom flow-thru set-up like mine...
Old May 27, 2012 | 08:08 PM
05Slowline's Avatar
been there done that, opt b stayed on.
Old May 27, 2012 | 08:58 PM
damn ok thats what i've been doing stop fill stop fill. Can you give me detail instruction on ur custom on or should i just get option B
Old May 27, 2012 | 09:34 PM
05Slowline's Avatar
custom one is meh. flow through is only going to be considered to be advantageous over opt b in the fact that you can put ice in it if you're at the track. at that point you're grasping at air though imo. the one pictured doesn't bleed air either.
