Coolant Temp Bouncing
Old May 27, 2012 | 09:42 PM
06cobalt racer's Avatar
why would you say that it wouldnt bleed air?
Old May 27, 2012 | 09:58 PM
Originally Posted by Murdered SS
damn ok thats what i've been doing stop fill stop fill. Can you give me detail instruction on ur custom on or should i just get option B
its pretty easy to install/make. grab about 12 feet of heater hose a universal coolant recovery tank and the 2 fittings that go into the tank.
on the stock filler neck there are 2 lines going to it, a supply and a return. the tank you buy completely replaces this. just run your lines over to the passenger fender. i ran mine under the passenger headlight bracket.
Old May 27, 2012 | 10:51 PM
05Slowline's Avatar
because it doesn't? where is your bleeder line?
Old May 28, 2012 | 12:36 AM
Murdered SS's Avatar
Ok I'll try that see how it works. thanks for the info i will keep checking on my temp
Old May 28, 2012 | 04:25 PM
If i want to drain the system whats the best way to drain and fill it?
Old May 28, 2012 | 04:52 PM
05Slowline's Avatar
remove the line from the side of the ic pump is the easiest. then in your case just fill drive fill drive etc.
if it is the stock clip on it take a crescent wrench or something of the like and grab on, then move up down up down until the glue lets go.
Old May 28, 2012 | 06:25 PM
ok coo thanks
Old May 31, 2012 | 10:32 PM
So I ve been watching my temp's and today was the day that the good ol las vegas heat is getting up there. by the time i got home the car was reaching 223 before when crusing it was at 183. Now since i installed the H\e it getting higher should i be worried? Did i do something wrong or something. Is that normal my temp seem higher than before.
Old May 31, 2012 | 10:47 PM
my engine temps never changed after adding my he
Old Jun 5, 2012 | 05:44 PM
Yea i dont know what i did wrong or what got messed up. I'm thinking i need a new IC pump
Old Jun 5, 2012 | 07:33 PM
  #36
Edubs's Avatar
The h/e coolant system has no impact on the engine cooling system.
Is your fan turning on?
Old Jun 5, 2012 | 10:45 PM
  #37
05Slowline's Avatar
normal maybe a tad higher than normal on the idling temp....
x's 2 on fan. if you get tuned you can also command the fans on earlier, or all the time (which is annoying imo)
Old Jun 6, 2012 | 10:07 PM
  #38
yea i need a tune
Old Jun 8, 2012 | 11:52 PM
  #39
ionit2004's Avatar
Kinda a stupid question but is the black air dam still on the car? Mine did the same thing after I hit a pot hole and was torn off the car.
Old Jun 9, 2012 | 02:18 AM
  #40
Yes mine is still on.
brandon04
Oct 21, 2015 07:04 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
z28addiction
Sep 28, 2015 12:03 AM
jmelton327
Sep 26, 2015 10:04 PM
riceburner
Sep 26, 2015 12:57 AM
