coolant temp display and a/c
Old Jul 23, 2011 | 01:10 AM
  #51
Maven's Avatar
Sorry Bika, I wasnt addressing your issue in particular at all. chances are that your thermostat is in actuality failing, its just not far enough out of spec yet to set the code and therefore trigger the other reactions.
Old Jul 23, 2011 | 01:14 AM
  #52
ItalianJoe1's Avatar
Originally Posted by Bika
Again, what does just a low operating temp indicate? Maven, you're saying that my t-stat is not bad since its not blanking out the ect reading or throwing the cel? The car is showing no indication of anything being wrong other than the temp is 20 - 30 degrees colder than it used to be.
That sounds like a stuck open/missing t-stat
Old Jul 25, 2011 | 01:33 PM
  #53
Bika's Avatar
Fail Less.
ok thanks. just wanted to confirm my suspicions
Old Apr 24, 2015 | 10:04 AM
  #54
CobaltNovice's Avatar
Problem Solved
As much as this doesn't make sense, this is what worked for me. I have a Cobalt Ls 2.2 liter and since about last December the digital read out would go in and out. One week I would have a temperature read out and the next it would say ---F and my check engine light would come on and the A/C would stop working. So, after reading through some trouble shooting I replaced the temp sensor. Not a hard fix and cost me about $25. This did not work.
So I went back to the auto stir and bought a thermostat and coolant which cost me about $40 bucks. And bingo. That was it. I get it, it makes no sense.. But it worked. Engine light went off. A/C works fine. And I'm getting a read out every time. The cobalt lives to fight another day.
Old Apr 24, 2015 | 10:05 AM
  #55
Problem Solved!!
Old Apr 24, 2015 | 10:28 AM
  #56
Yeah the thermostat does that ^
Old Apr 24, 2015 | 09:03 PM
  #57
Jesse's Avatar
Yes. This is because if your car doesn't reach a certain temp in a certain amount of time, the computer assumes your thermostat is failed (they fail open) and ignores the reading entirely. If you're someone like me who revised his fan settings or lived in a cold-ass place, you'll get this code no matter what.
My solution was to disable the P0128 code. Replacing the thermostat also works.
Old Aug 5, 2015 | 05:44 PM
  #58
Vallador's Avatar
I changed the coolant sensor and the t stat and sill temp is either not reading --- 'F or the temp is jumping around saying its overheating when it's not going from 90' to 240' back down and up
Old Aug 5, 2015 | 06:02 PM
  #59
exninja's Avatar
Maybe there's an issue with the connection or the PCM itself
Old Aug 5, 2015 | 10:50 PM
  #60
Vallador's Avatar
Yeah the dealership tried to tell me it's the cluster but I don't think that's what it is
Old Aug 6, 2015 | 11:58 AM
  #61
exninja's Avatar
You can easily rule out the cluster with an OBDII scan tool
Old Aug 6, 2015 | 08:06 PM
  #62
Vallador's Avatar
Really?
Old Aug 6, 2015 | 08:31 PM
  #63
exninja's Avatar
Sure. If your scan tool reads good temps but the cluster doesn't then you know the cluster is bad. If the scan tool reads bad temps then you know it's not the cluster. I assume you're talking about the dash cluster?
Old Aug 6, 2015 | 09:23 PM
  #64
Vallador's Avatar
Yes
Old Sep 9, 2015 | 08:51 PM
  #65
Blaine23's Avatar
Originally Posted by Malaclypse
Yes, you need to replace the thermostat. That will take care of it.
Had my stat replaced worked fine for about a week and a/c quit working again the coolant temp shows ---f° now?
Old Sep 9, 2015 | 09:10 PM
  #66
exninja's Avatar
Referring back to this post
Edit, just noticed you're new to the thread. Did you check the ect sensor?
Old Sep 9, 2015 | 09:33 PM
  #67
Blaine23's Avatar
Not yet. I haven't had the chance yet that will be this weekends project. If that doesn't fix it is there anything else to check?
Old Sep 10, 2015 | 01:07 AM
  #68
Jesse's Avatar
This is false. My scan tool read temps fine and the dash still read ---*. Disabling the P0128 solved the problem but I realize not everyone can just tune their problems away.
Old Sep 10, 2015 | 01:18 AM
  #69
exninja's Avatar
Huh. Weird.
Old Aug 3, 2018 | 01:00 PM
  #70
TJ Smith's Avatar
A/c
Originally Posted by army_greywolf
Yes replace T-Stat, if you have access to a scan tool that can look at your ECT Sensor temp, be sure to verify it as working before you do so. Apparently part of the P0128 code is that it changes the tables on the car's ecu in which part of it disables reported coolant temp (the --- on the display) and turns off the air conditioning(body control module function) which is simply a direct result of lack of reported input (any temp not reported or below 32F). It appears this is a incorrect programming issue from GM and several other manufacturers who use the same series of ECU. On fords, reporting the P0128 it does NOT shut off the a/c nor does it zero out the reported temp. It also sets the SES light. I dealt with the exact problem twice this week on a 07 F150 and 06F150 respectively. Malaclypse, sorry man, just never assumed the ECU command to disable reporting.
When the A/C is being disabled, should it be overcharging? I’m having the same issues and I’m gonna change thermostat tonight but when I felt the A/C warm I went and got some freon and when I connected it to the system the gauge went all the way to the right as far as it would go. Needless to say there was too much pressure to add any freon. Would the computer disabling the A/C compressor or clutch cause this?
Isaac Lewis
Jan 1, 2017 04:48 PM
FF_ace
Jan 8, 2015 06:17 PM
shawn
Dec 1, 2012 06:26 PM
MP81
Jul 12, 2008 04:59 PM
