Coolant temperature/fan question
Old Oct 18, 2007 | 08:45 AM
Ser_Fed's Avatar
Hi All,
Please tell me what should be an engine coolant temperature to make cooler fan go on? (2006 Cobalt LS, 2.2)
I have a feeling that mine does not work at all.
Thanks
Old Oct 18, 2007 | 08:47 AM
Coblt ss super's Avatar
put a toggle switch to it, search the how to's i think theres one on how to do that
Old Oct 18, 2007 | 08:49 AM
sick06cobalt's Avatar
is your car running hot? the fans turn on at about 210 or something like that.... mine was running hot so i mean this should be intresting....
Old Oct 18, 2007 | 08:51 AM
mkulrey13's Avatar
dont worry about it till it gets near 260ish
Old Oct 18, 2007 | 09:04 AM
fr33k's Avatar
Here's an insert out of the "Cooling System Description and Operation" on GM's Service Information site.
The ECM commands Low Speed Fans ON under the following conditions:
• Engine coolant temperature (ECT) exceeds approximately 106°C (223°F).
• A/C refrigerant pressure exceeds 1 310 kPa (190 psi).
• After the vehicle is shut off, the ECT at key-off is greater than 140°C (284°F) and system voltage is more than 12 volts. The fans will stay on for approximately 3 minutes.
The ECM commands High Speed Fans ON under the following conditions:
• ECT reaches 110°C (230°F).
• A/C refrigerant pressure exceeds 1 655 kPa (240 psi).
• When certain DTCs set
Old Oct 18, 2007 | 11:40 AM
Renesis's Avatar
uh, I hear mine start before that and I always freak out when it gets about 96C.
Sometimes I even turn 'em on manually with my dashhawk to cool it down a 'lil
I guess I'll sleep better now, thanks and +rep for an info I wanted for a long time.
are those stats valid for the 2,4 too though?
Old Oct 18, 2007 | 05:08 PM
fr33k's Avatar
It shows the same stuff for all the engines. Here's the actual page from GMDealerworld.com on the cooling description.
http://fr33k.5gbfree.com/cooling.htm
sorry for the ads. they sux. But, it's free
brandon04
Oct 21, 2015 07:04 AM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
grampss
Sep 27, 2015 08:51 PM
riceburner
Sep 26, 2015 12:57 AM
