cracked!
Old Mar 14, 2007 | 11:08 PM
beamSS's Avatar
cracked!
i saw my two cracked pistons tonight. It was fractured along the ringland. good thing the rings held it together not causing any damage to the sleeves. what do you think could have caused this? mechanic said it wasnt able to handle the boost i threw at it. what the heck? i was only using 2.8 / 16.5l psi. so what do you think?
Old Mar 14, 2007 | 11:11 PM
Red2.4SS's Avatar
It must have been detonating, possibly due to improper tune or maybe bad gas??
Old Mar 14, 2007 | 11:12 PM
beamSS's Avatar
maybe so. it was tuned for warm weather and it went when it was 0 outside. i didnt have a chance to have it retuned for the cold weather.
Old Mar 14, 2007 | 11:17 PM
Red2.4SS's Avatar
Sounds like its a good possibility then that your engine went a little lean with the colder air and blew!
Old Mar 14, 2007 | 11:19 PM
Red2.4SS/SC's Avatar
so wait you blew your motor yet you could still drive on it legitly
Old Mar 15, 2007 | 01:37 AM
tcolli17's Avatar
more details please.
Old Mar 15, 2007 | 02:04 AM
lsjwannabe's Avatar
#4 piston right
Old Mar 15, 2007 | 02:08 AM
NJHK's Avatar
Yeah bro...you leaned out hard...
Old Mar 15, 2007 | 04:09 AM
can you please elaborate on this motor blowing situation did you know you blew your motor right away or what
Old Mar 15, 2007 | 07:28 AM
beamSS's Avatar
no i didnt know i blew it yet. i popped a dipstick and tried to change the intake manifold gasket but still it pops my dipstick. so i decided to have a compression test and found out that i have lost compression on 1st and 4th. both pistons are fractured the same way. i still drove the car for a good fifteen miles going to the mechanic. mechanic was suprised cuz it didnt leave any damage to the block because the fractured parts were held together by the piston rings.top part of pistons were in mint condition. il post pics later.
Old Mar 15, 2007 | 07:36 AM
06blackg85ss's Avatar
damn man another LSJ bites the dust
Old Mar 15, 2007 | 07:39 AM
distillion's Avatar
^^due to tuning....
Old Mar 15, 2007 | 07:59 AM
cobaltstg2's Avatar
ahh... just came from there bro... yeah your 2.8 leaned out and then went boom with the cold air..
trust me it gets better
Old Mar 15, 2007 | 08:06 AM
beamSS's Avatar
motor is going together so ill have a built motor friday. i put in arp headstuds, cometic gasket, diamond pistons with total seal rings. they had to machine the rod for the piston pin to fit.
Old Mar 15, 2007 | 08:08 AM
oh really.... it shouldn't been a direct replacement. I hope you stayed with a max of 9.5:1 compression though.
Old Mar 15, 2007 | 02:29 PM
tcolli17's Avatar
I'm guessing you don't have a wideband.
Old Mar 15, 2007 | 02:40 PM
AMG_Passion's Avatar
Ahhh self compensating stand-alones are amazing. 28psi at 0 degrees runs just as rich as 28psi at 90 degrees, all without ever touching the tune....Too bad i cant afford to put a 4,000 EMS into my cobalt.
Old Mar 15, 2007 | 02:41 PM
the cobalts PCM will auto adjust too... problem is most people modify or disable the abilty of the PCM to do so.
or they're running a 2.7 pulley on 42 lb injectors... and just lean the hell out
Last edited by 06blackg85ss; Mar 15, 2007 at 02:41 PM. Reason: Automerged Doublepost
Old Mar 15, 2007 | 04:11 PM
beamSS's Avatar
im only running 2.8 + 60#. but with warm tune.
Old Mar 15, 2007 | 04:21 PM
Gixxerboy02's Avatar
Im getting ready to do my upgrades with in the next week or so.Im running
2.7 pulley
65# injectors/harness
zex plugs
ecotec header
down pipe no cat
megan racing catback
injen intake
will i have to get it retuned with every season change? I dont wanna blow my motor it only has 1100 miles
Old Mar 16, 2007 | 12:18 AM
beamSS's Avatar
i guess just for winter and summer
Old Mar 16, 2007 | 10:12 AM
blktrax's Avatar
You got Deta-owned, just be glad your not picking chunks of connecting rod the size of quarters out of the oil pan.
I remeber that day 60 miles from home at the track in an 85 Dodge charger turbo. The hell with it, drove it home on 3 cyclinders and no boost, Misquito control was on patrol.
DANRICKARD
Oct 1, 2015 12:08 AM
Cptnslo
Sep 24, 2015 09:32 AM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
Getaway_Driver
Sep 8, 2015 09:41 AM
frost3
Sep 3, 2015 12:20 PM
