cracked exhaust manifold.
Old Jan 19, 2013 | 06:36 PM
turbosmart4's Avatar
Question cracked exhaust manifold.
Can it throw lean code p0171? I can hear a buzzing sound sometimes when I step on it on cold starts
.. Name:  IMAG0391.jpg
Old Jan 19, 2013 | 06:56 PM
Hope ya can see the crack above the numbers
Old Jan 19, 2013 | 06:57 PM
SylverSS/SC's Avatar
I can see it. not sure if it will affect you much.
Old Jan 19, 2013 | 06:59 PM
I've been throwing the code for a while and I can hear a buzzing sound
Old Jan 19, 2013 | 07:03 PM
kzak104's Avatar
i pulled off a zzp manifold that was cracked before, ended up being warped aswell, made a rattling sound when cold, huge exhaust leak. this car threw a lean on decel code, i forget what the actual code was tho.
Old Jan 19, 2013 | 07:06 PM
Well that's shockin! Zzp header went bad did they have waranty??
Old Jan 19, 2013 | 07:11 PM
kzak104's Avatar
i dont think so, the guy just ended up buying a new one (the revised one that has relieve cuts) but a turbo did blow on the manifold previously.
Old Jan 20, 2013 | 12:18 PM
I just hope this is what's causing the lean code lol
Old Jan 20, 2013 | 12:25 PM
prevsrt4owner's Avatar
Dawg, you have a vacuum leak. I'll bet your LTFT are in the positive double digits, right?!
Boost leak test with soapy water to find the leak. You can also smoke test it.
Old Jan 20, 2013 | 01:32 PM
I used soapy water and found nothing lol then I used carb cleaner and no luck either.. and I thought the crack could b the issue since its before the 02 sensors but need more advise :P
Old Jan 20, 2013 | 04:22 PM
sLAsh's Avatar
Yes an exhaust leak before the o2 sensor can give you a lean code. When u get off the gas it pulls in air and throws the code
Old Jan 20, 2013 | 07:09 PM
Alright , thanks will be buying a used header soon :P
Old Feb 13, 2013 | 07:54 AM
Well after receiving mongorat's mani I decided to replace the cracked one
Removed heat shield and this is what I found Name:  IMAG0455.jpg
Old Feb 13, 2013 | 08:28 PM
kzak104's Avatar
yup, thats cracked, ha
Old Feb 13, 2013 | 08:59 PM
SlowCobaltSS's Avatar
I have a spare exh manifold sitting around
Old Feb 14, 2013 | 09:24 AM
Just installed a mani from mongo guys.. thanks though :
Old Feb 27, 2013 | 07:47 PM
mahfouzman's Avatar
Your exhaust manifold shouldn't be throwing that code, do you have an aftermarket intake? Or did you do the airbox mod perhaps? Before I got tuned, my car was throwing that code because of the airbox mod, because of the extra air coming into the engine.
Old Feb 27, 2013 | 08:11 PM
I haven't seen the code ever since I replaced the mani and I don't even have an intake lol
Old Feb 27, 2013 | 08:42 PM
mahfouzman's Avatar
Really? Hmm...I used to get that code for my intake haha, even when my mani was cracked I never threw that code. Well glad you got it sorted out
Old Feb 27, 2013 | 09:09 PM
: mani things can throw the code, even a dip stick that's not sitting properly lol
Old Mar 1, 2013 | 01:38 PM
SSROKETZ28's Avatar
I kinda got the same or at least a similar issue... should start my own thread but I figured id chime in.. the only difference is I get that code and that leaky buzzing sound even after replacing the crappy manifold and dp the car had when I bought it.. put a new mad-nab headers and zzp catted dp.. still getting that noise.. fml
Old Mar 1, 2013 | 01:42 PM
Same here I get a buzzing sound unde boost but no more code... I think it might b the gasket?
Old Mar 1, 2013 | 02:18 PM
SSROKETZ28's Avatar
does that mean I keep blowing gaskets or something..? the car sounded normal for a couple of days after I put in header and dp.. and then back to that dumb noise..
Old Mar 1, 2013 | 02:21 PM
Try tightneing the bolts , maybe they are not torqued right
Old Mar 1, 2013 | 02:24 PM
jonathan923's Avatar
have you checked the flexpipe? those tend to crack alot more often than manifolds do
