Cronic Ignition problems in the cold
Old Oct 22, 2007 | 08:50 PM
MarcS's Avatar
The Stig
So this is the 3rd time my car has been experiencing "starting" problems when the temp drops. The last time I took it in they told me it was a coil pack. My question is how can a coil pack go bad every winter?
Any ideas?
Syptoms:
Progressively worsening condition
Needs throttle to start
Sputtering
Black smoke from exhaust
Old Oct 22, 2007 | 09:21 PM
Coblasts's Avatar
Did the new coil pack solve the issue.
Check the Battery voltage,when its cold .
A lower voltage could cause harder starting due to less spark.A coil usually works or it doesnt unless you have a bad connection.
Get them to reflash the car .Maybe the cold start program is corrupted.
Old Oct 22, 2007 | 09:37 PM
MarcS's Avatar
The Stig
It was last spring when I had it fixed when they told me they replaced a coil. I'll have to check the battery in the morning. thanks.
Old Oct 22, 2007 | 09:44 PM
BLKLS's Avatar
get a hydormeter and check the that way if you have a bad cell and check it with a meter it could still show good voltage. the hydrometer will look for a bad cell, if the reading is off more then 25 points between cells its a bad battery.
turbochargedss2012
Sep 20, 2023 12:17 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
OrangeCoba
Sep 25, 2015 06:06 PM
