Cruise Control Problems?
Old Jan 23, 2009 | 11:05 PM
BallinBlackbaltSS's Avatar
Talking Cruise Control Problems?
I have an 06 Chevy cobalt SS/SC i just had it in the shop because cruise control didnt work. They called and said clutch slipped and sent a code not alowing cruise to set. I got it fixed but now i still cant seem to get cruise to set, I look at the dash as it says cruise engaged and it flicks on then flicks off really quickly. and doesnt set
Any suggestions? that would be great thanks.
Old Jan 23, 2009 | 11:13 PM
NS06G5's Avatar
give your switch a good wack worked for me. Mine wouldn't engage, got mad, gave it a good push and it must not of been making full contact. Works great now.
Old Jan 28, 2009 | 11:01 PM
06CobaltSS635SC's Avatar
mines doing the same thing, it started the same time that my cd player got screwed up. It says check disk and when i try to play the cd it says no disk, when i hit the eject button it says no disk but there is a disk in there. Going in to the shop when ever they get an opening, any ideas?
Old Jan 29, 2009 | 12:16 AM
cli3e0339384398jk's Avatar
search button is your friend, it is the position sensor for clutch the throws a code and causes it to disable, get someone to reset the code for you or disconnect your battery for 10 minutes and then it will work again
Old Jan 29, 2009 | 05:08 PM
ya I had that done but now the cruise still doesnt work, i hit the cruise button and it will say cruise engaged for about a second then go off right away. Still not setting my speed.
Old Jan 29, 2009 | 07:49 PM
DaBuzzard's Avatar
Upper clutch switch bad maybe, or out of adjust?
Hmmmm, maybe a brake light switch? Be pretty easy to tell if someone was to follow you, see if the brake lights are flickering maybe. Had that happen on an my wifes Taurus - switch for the third brake light broke so it was on all the time and of course, the cruise would not set because it thought the brake was being used and so disengaging.
Judging from what I've seen on here, I'd bet on the clutch switch though
Old Jan 29, 2009 | 07:56 PM
Swan SS's Avatar
had the same problem on my 06 ss/sc... took it to the dealer about 5 different times... finally came to the conclusion that its a bad switch in the steering wheel. Dealer in FL said he's had a few of these come through. This is after my dealer in IL replaced the clutch position sensor 3 times. So far cruise has been working.... hope this helps.
Old Jan 29, 2009 | 07:58 PM
greekss's Avatar
same thing is happening to me...twice now...
Old Jan 29, 2009 | 11:37 PM
they can also adjust the sensors to be less sensitive as well, this is what they did with mine last and has been good since.
Old Feb 13, 2009 | 01:49 AM
if anyone ends up having this problem to i finaly got my car into the dealership to get the cruise control fixed. Ended up being that when my car was stuck in the mud and trying to get it out and feathering the clutch alot it threw a clutch safty code which does not alow the cruise control to be set untill it is cleared. Ended up being that if you hold your clutch down for a long period of time, for example keeping the clutch in a little to Get your car out of the mud the computer thinks that the clutch is stuck somewhat engaged and throws a code which didnt allow the cruise control to be set. Dealer cleared the code and as good as new again. As for my cd player tho they had to order me a new one, unknown reason on why it is having the cd issue.
Old Feb 14, 2009 | 05:38 PM
Talking
Well i had it fixed again, then it went out again so i took advice and unplugged the battery for 10 minutes and that worked. So if you dont have time to take it to dealer just undo the battery terminal for 10 minutes and it resets it. Aka dont rest your foot on clutch while driving either that also throws the code. Thanks
Old Feb 16, 2009 | 01:26 PM
DaBuzzard's Avatar
Originally Posted by BallinBlackbaltSS
----snip-----
And burns up your clutch
Old Feb 17, 2009 | 03:21 PM
hah yea... pretty much..
ColonelMustard
North Pacific
Sep 29, 2015 03:02 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
jrocstar
Sep 26, 2015 11:42 PM
Coballin13
Sep 25, 2015 08:43 AM
