Cruise Issue
Old Sep 16, 2009 | 04:27 PM
Smus's Avatar
Cruise Issue
Ok, so my cruise hasn't worked now for a few weeks.
I've heard it can be an issue with the 3rd tail light. I was wondering how you replace those exactly. I know that one is out for sure, the other works intermittently.
Thanks for the help
Old Sep 16, 2009 | 04:35 PM
twzted's Avatar
unhook your battery for 10 min and reconnect it...should work
if you cruise is where you hit the button and then it flashes on and then off this is your fix...
also keep your foot of the clutch
Old Sep 16, 2009 | 04:38 PM
FastSSinNH's Avatar
Really? Im gunna try that. Ive had that problem for months.
Old Sep 16, 2009 | 04:55 PM
rnjmur's Avatar
Problem can be caused by a couple of different things.
1. If you ride the clutch the computer will throw a code thinking that the clutch sensor is bad or if the clutch sensor does go bad it will throw a code. The code is "invisible" and does not cause the check engine light to come on.
2. If the brake switch is bad. (Normally this one is easy to tell because your brake lights don't come on)
3. If the sensor that detects what gear you are in goes bad or if you release the clutch x number of times (I don't remember how many times it is... I think maybe 10 times??) without changing gears it will cause the computer to throw another "invisible" code that the sensor that detects what gear you are in is bad.
As long as the actual sensor is not bad you can disconnect the battery for 10 minutes then reconnect the battery and it will clear the code. If the cruise control still doesn't work you will need to go have the codes read to see which code is causing the cruise to be disabled.
Old Sep 18, 2009 | 02:12 AM
Smus's Avatar
Awesome, thanks guys!
Old Sep 23, 2009 | 07:32 PM
FastSSinNH's Avatar
Oh my god! I tried this today and it worked! I cant believe this friggen worked!
Tupp
Sep 30, 2015 08:18 PM
ColonelMustard
North Pacific
Sep 29, 2015 03:02 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
jrocstar
Sep 26, 2015 11:42 PM
