Damn Bolt fall into the duct vent ?????? how to remove it ????
Old May 1, 2006 | 10:48 PM
One Bad SS's Avatar
I went to the garage to get my window tinted and the guy remove a bolt from the door trim, put it on the dash, he try to clean my window and kick the bolt then it fall into the duct vent on the top of the dash, now when i turn i hear the little bolt going left to right inside the dash. What i can do to remove that ****, i think it around the air bag or near the glove box, i try to remove the glove box and check inside but i found anything
Old May 1, 2006 | 10:59 PM
Numicus315's Avatar
ahh.. that would annoy me so much... maybe try taking the dash apart?? it would depend if it fell in the air vent or jsu tin between the dash.. Make him pay for it to get taken out.. so you dont have to worry about it
Old May 1, 2006 | 11:14 PM
zomghax's Avatar
My dad jury rigged up a little tool once for something or other (my dad is always making and doing crazy crap), a small magnet on the end of a long (yet stiff) spring. Take a walk up the aisles of a hardware store, be creative and see if you can find something to fix your problem that doesn't require you ripping your dash apart
(Unless you think it's so far down in the depths of the Sarlak pit that no fishing is going to get it. Then just ignore me like I do the voices!)
Old May 2, 2006 | 12:56 AM
djpatrick35's Avatar
Use a magnet attached to the end of a plumber snake or something. You should be able to get it if you have a strong enough magnet and something that'll be able to get around the corners of the ducting
DarrenGC
Dec 24, 2021 01:55 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
