Damn Cobalt
Old Oct 24, 2008 | 09:31 PM
Altiery54's Avatar
Damn Cobalt
Well i have been having an idle/surging problem for awhile now and finally tried some things. Pulled my TB spacer off and bam methanol everywhere so i clean that up and the inlet of the blower throw on my tb w/o the spacer crank it down start the car idles 80% better still the ocassional miss but farther apart and not as obvious. the whole reason i checked is after driving 5 minutes home from work i get a funky burning smell(the smell if u ride the **** outta your breaks smell) i never hit brakes hard. pop hood and a lil coloud of steam/smoke now with my meth unhooked and the nozzle laying on the car i notice that i have a leak on my nozzle i believe its a bad check valve which explains the running rich at idle and y it could not be tuned out. now i need 2 move my pulley over a tad bit to make it perfectly aligned and hopefully thats causing my miss. about the cloud of smoke i have no fricken clue. meth kits coming out of the car for now and going back 2 the 2.8 and 60s non meth tune and going from there
Old Oct 24, 2008 | 09:52 PM
KillerBee's Avatar
you sure its not dumping meth in more then it needs
Old Oct 24, 2008 | 09:54 PM
Altiery54's Avatar
i dont follow? the check valve is not working 100% so i have a leak which is causing my car to idle funky
Old Oct 24, 2008 | 09:56 PM
KillerBee's Avatar
What i ment is that the meth could have cause the cloud of smoke if its not that then it could to be a blown head gasket.
Old Oct 24, 2008 | 09:59 PM
Altiery54's Avatar
quite possibly. the TB was iceeeeee cold. head gasket i gotta figure out how to check that
Old Oct 24, 2008 | 10:00 PM
KillerBee's Avatar
check your oil for the head gasket for a creamy look and if it smells like burnt coolant that could be it too.
Old Oct 24, 2008 | 10:01 PM
Altiery54's Avatar
definetly got the burnt coolant smell when i came home
Old Oct 24, 2008 | 10:05 PM
KillerBee's Avatar
humm check your coolant levels and your oil that should tell you
Old Oct 24, 2008 | 10:06 PM
Altiery54's Avatar
so look for discolored oil and burnt smelling in the coolant?
Old Oct 24, 2008 | 10:08 PM
KillerBee's Avatar
the smell will only be there if its been running and look around the head see if you see coolant leaking any where. The oil is normally a creamy color when it mixes with coolant.
Old Oct 24, 2008 | 10:09 PM
Altiery54's Avatar
brb hommie gonna go check
Old Oct 24, 2008 | 10:10 PM
KillerBee's Avatar
ok did you disconnect your meth after or before you opened the hood with a cloud of smoke?
Old Oct 24, 2008 | 10:18 PM
Altiery54's Avatar
i disconected the meth after the little bit of smoke. oil and coolant looks fine
Old Oct 24, 2008 | 10:20 PM
KillerBee's Avatar
Well then you start her up and take her for a drive if it dont smell like burnt coolant then it was the meth that was burning
Old Oct 24, 2008 | 10:23 PM
Altiery54's Avatar
i have a leaking check valve so i need a new 1
Old Oct 24, 2008 | 10:25 PM
KillerBee's Avatar
oh ok well time to buy a new check valve.
Old Oct 24, 2008 | 10:27 PM
Altiery54's Avatar
just did wont do any good tho wont have it till tuesday
Turbo Johnny
Feb 21, 2019 09:41 AM
Hugger1975
Oct 15, 2015 03:28 PM
Rayray2781@gmail.com
Sep 20, 2015 01:52 PM
