dash rattle
My factory head unit started cherping and a bit of a rattle. pop everything off and tighten the screws past w/e the the factory torque was suposed to be. The glove box issue is that its made of brittle plastic and resonates anything thats inside of it. the fix is to not have anything metal or plastic or wood in there. I guess you could line the inside with something as well.
About the rear, check out the seats first, alot of people were getting a cherping in the rear and it ended up being where the seats hook onto the chasis. the rear deck i pulled apart and sound deadend the crap out of it and put it back together.
A cheap way to just kill the rattle is buy a bag of rags and stuff it. Lol, thats not a great suggestion but itll work.
hope that helps
hope that helps
you can fix the rattle 3m makes this stuff http://multimedia.mmm.com/mws/mediaw...666xB4COrrrrQ-
(you can buy this stuff as a roll at pepboys)
ive used it for some parts on the dash and it fixed it...also that squeak in the back seats... they also have some other stuff go to 3m.com and view specialty squeak/rattle vibration tapes... **** works man
