Dashboard gauges going crazy whilst driving, on video.
Old Sep 14, 2012 | 04:02 PM
trentonwayne's Avatar
Can anybody help please.
Chevy Cobalt 2006 problem - YouTube
...this happened once last year for 5 seconds, then it never happened again. This time it lasted 8 minutes. No problems with driving unless i would stop, then under 15 mph it would hesitate to stay running, the shifting would struggle from 1-2 and 2-3 and almost die. Automatic engine.
Mods are as follows:
Power Control Module | Stage 2
Part #: 10608S
JET V-Force Plus Performance Module
Part #: 68021
Powr-Flo Mass Air Sensor
Part #: 69143
Mods were installed 2.5 years ago. Pretty sure the mods are not the problem.
thanks for your help Cobaltss, hope we can figure this out.
Old Sep 14, 2012 | 07:24 PM
redcobalt07's Avatar
Those mods seem sketchy
Old Sep 16, 2012 | 03:14 AM
insylem's Avatar
Looks similar to or a varation of this malfuctnion
https://www.cobaltss.net/forums/prob...roblem-275828/
Like you said with me, it happened, then goes away for a long time then happens again at random. WIth me, when I stoped the problem cleared itself. It set a few codes wich i put in the linked thread. If you want get your codes scaned at the dealership, autozones scanner only reads PCM codes, you probaly have BCM codes like I did. Cost me like 40 bux.
Old Sep 16, 2012 | 03:35 AM
Reklo87's Avatar
That is a good video of that problem. Mine has been doing that a while now, just less of a deflection. I grounded out the TCM case to the car and has helped. It is still doing it but it is less. I think I have bad TCM.
Old Sep 16, 2012 | 03:49 AM
FryLoch's Avatar
Could someone edit in some dubstep to that video?
Old Sep 16, 2012 | 08:34 AM
06cobalt racer's Avatar
ha ha ha what i was thinking
Old Sep 16, 2012 | 02:18 PM
insylem's Avatar
I didnt think the SS trim levels have TCMs?
Old Sep 16, 2012 | 06:43 PM
Ceej's Avatar
I lol'd so hard
Old Sep 21, 2012 | 04:05 AM
Dub step, genius!! hahahaha
no luck a of now, will keep you posted..
Old Apr 8, 2013 | 07:19 PM
Confirmed. My cruise control has an effect on the code. 90 percent of the time when i use cruise, the U0073 code triggers. sometimes within 10 minutes, other times with in 2 hours. Ideas?
Old Sep 5, 2013 | 10:52 AM
As of now 9-5-2013, still having the problem. Happens even when the car isn't running, just in the "ON" position. Thoughts?
Old Sep 27, 2013 | 06:02 AM
happened in park.
Old Sep 28, 2013 | 10:29 PM
W34K54UC3's Avatar
Crazy Guages
I had this issue with my SS/TC when I first got it (pre-owned) this year.. Some electrical testing led me to a bad ground. Found the battery in the trunk, cleaned off the negative terminal and tightened the connection back down. VOILA, no more crazy gauges! Hope this helps!
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
Sep 27, 2015 08:53 PM
DocSvensk
Sep 27, 2015 02:24 PM
