Diagnosing exhaust rattle (not heat shield)
Old Aug 27, 2015 | 07:27 PM
brickloaf's Avatar
Once I get over 2k rpm I get a real "tinny" rattle noise, almost like a few pennies bouncing around in a coffee can. I checked the heat shield, put some screws in it, and bent back anything that could be making contact with the exhaust. The downpipe was replaced a year ago with a ZZP one, and there don't appear to be any holes in the resonator and the straight pipe that leads to the rear of the car (muffler is removed). The sound almost sounds like its coming from underneath the radio but its hard to know exactly because I can only get the rattling sound when I am driving. Anyone have any suggestions? Im thinking of just replacing everything after the downpipe but would hate to replace all that and still have issues. Any help appreciated!
Old Aug 27, 2015 | 08:05 PM
double clutch's Avatar
Resonators can come apart on the inside and not be visible
Old Aug 27, 2015 | 08:37 PM
brickloaf's Avatar
Wouldn't I be able to hear **** clanking around if I took the resonator out and shook it? If it was the resonator that was bad.
Old Aug 29, 2015 | 04:38 PM
brickloaf's Avatar
bump. I am about to go under there again, any input appreciated.
Old Aug 29, 2015 | 04:52 PM
Yea you should be able to hear it rattling. Check all your exhaust hangers and make sure its not touching the body anywhere
Old Aug 29, 2015 | 08:15 PM
no_ss's Avatar
I heard putting hose clamps around the rubber exhaust hangers helps with this.
Old Aug 29, 2015 | 08:59 PM
tomj77's Avatar
I had issue with Hahn exhaust, A set of hangers were touching so I put rubber between them. Issue solved
Old Aug 30, 2015 | 08:59 PM
brickloaf's Avatar
Turns out the bolts that connect the downpipe to the resonator had come a little loose, just enough to cause vibration. Fixed for now, although I wouldn't be surprised if the same issue comes back in 10-15k miles... Thanks anyways guys, that had been bugging me for a while now.
Solaris99
28
Mar 15, 2017 01:22 PM
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
jimbofug007
Oct 2, 2015 12:06 PM
jmelton327
Sep 26, 2015 10:04 PM
