Diagnosing no power
Old Mar 11, 2015 | 04:22 AM
prmths's Avatar
Diagnosing no power
Hello all, new here. I've noticed that my 2006 ss has no power, when driving at any speed. I find myself worrying about getting up hills. It's running hotter than normal but not overheating (normal temp is roughly 180 now it's closer to 220 and hot when taking a hill), the boost gauge is saying it's making boost, when there is clearly no power.
I've not checked the fluid at the IC pump because I don't seem to have a filler neck. I have two coolant tanks but the tank on the driver's side appears to be overflow only, I don't see anything but one thin line running to it while the other is clearly running to the radiator.
Any help is greatly appreciated, I love this car and want it back.
Old Mar 11, 2015 | 01:55 PM
mrbelvedere's Avatar
the coolant tank on the left is for option heat exchanger system also called option b is there coolant in it
Old Mar 11, 2015 | 05:21 PM
CleverOne's Avatar
clogged cat?
take the cap off of the option b tank and turn the key to the accessory position, you should see flow.
If you just bought this car and haven't changed the IC pump you should do that, 9 times out of 10 that thing is bad.
Old Mar 11, 2015 | 05:41 PM
Originally Posted by CleverOne
clogged cat?
Not everyone has it tuned to turn the IC pump on with the key on. If he's been driving it for awhile then there is a good chance it should be on and flowing.
I second the clogged cat though
Solaris99
28
Mar 15, 2017 01:22 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
ernnyyes
Oct 2, 2015 05:16 PM
717ssbalt
Oct 2, 2015 04:01 PM
Stuff
Oct 1, 2015 05:47 PM
