Dielectric Grease
Old Mar 12, 2012 | 05:17 PM
SS_carnatic's Avatar
Dielectric Grease
Changing the spark plugs in a '06 HHR 2.4 thought i'd post on here as well.
What is the community knowledge of using dielectric grease when replacing the spark plugs. Yes or No?
Should it be applied to the end of the boot/coil before installing?
Thanks
Old Mar 12, 2012 | 06:22 PM
Malaclypse's Avatar
I've never done it in my 10 years as a mechanic and have had no problems.
On some vehicles the plug wires are held on just by the clip on the wire-end itself. So sometimes using di-electric would make the wires more prone to pop off. Not a problem in the case of any Ecotec... but I still don't use di-electric.
Old Mar 12, 2012 | 06:27 PM
05Slowline's Avatar
just put a lil anti sieze on the plug threads never put anything else on the spark system
Old Mar 12, 2012 | 06:38 PM
Silv3r's Avatar
I use dielectric grease on my plugs, just the ceramic boot and metal top (nothing below where it threads in). Never had any problems.
Old Mar 12, 2012 | 06:52 PM
Superbalt06's Avatar
I've never heard of using that on spark plugs but I've used it for o rings. Not all the time though most of the time I just use some spit. Anti seize is all you need on the plugs.
Old Mar 13, 2012 | 09:18 AM
quickboat's Avatar
If you were going to cross creeks in an off road vehicle, you may use dielectric grease on all of the electrical connections to prevent water shorting, but not in these cars...IMHO
Old Mar 13, 2012 | 11:21 AM
Looks like the general consensus is to just put some antiseize on the threads of the spark plug and just pop on the boot/coil with no grease.
Thanks
biniecki
Oct 25, 2015 02:23 PM
powerz
Dec 7, 2009 02:49 PM
ub3rn00ber
Jul 25, 2007 12:38 AM
eastcoastz
May 30, 2007 01:04 AM
Cobalt443
North East
105
Nov 12, 2006 01:41 PM
