Difficulty starting after refueling
Old Dec 29, 2011 | 02:39 PM
forced_induction's Avatar
So as the title states I am having trouble starting my car after I fill it up at the gas station. Basically what happens is after I refuel the car will crank over and then shut right back off if I don't immediately press the gas pedal. It also won't stay on unless I give it gas constantly until I can get it driving down the highway for about a mile or so, then it runs normally. I'm thinking it has something to do with the pressure in the fuel tank because one time when I went to fill up the gas station attendant had removed the gas cap before I shut the car off and once he took it off the car starting idling erratically, jumping from around 500-1500 rpms. This makes exiting the gas station very difficult since I have to constantly juggle blipping the throtle to keep her running and applying the brakes so I don't just roll out onto the highway in to traffic. Has anyone else experienced this problem or have any ideas as to what could be causeing this to happen. The car is a 06 ss/sc
Old Dec 29, 2011 | 02:41 PM
BLAZIN07SS's Avatar
I'm too JDM for you
you have a bad evap solenoid
Old Dec 29, 2011 | 02:43 PM
BLAZIN07SS's Avatar
I'm too JDM for you
Chevy GMC Buick Vapor Purge Canister Evaporator Valve EVAP (C25-3z)(Qty 1) | eBay
Old Dec 29, 2011 | 02:52 PM
Thanks man, I tried searching but I had no clue what could be causeing the problem so I couldn't find anything that sounded like what my car is doing
Old Dec 29, 2011 | 08:10 PM
Coblasts's Avatar
Evap purge selinoid ,located under the hood is the usual problem with those symptoms.
Easy to replace and cheap,it sits on the right side of the head when looking at the motor on the top edge.
Old Jan 1, 2012 | 01:07 PM
AzraelRaezier's Avatar
MY CAR HAS THIS SAME PROBLEM! thank god someone knows what it is cuz everyone ive talked to didnt know! PRISE BLAZING07SS! THANK YOU haha
Old Jan 1, 2012 | 01:34 PM
C_A_D88's Avatar
My dads car will do the same thing, right after fill up it will crank and crank and crank until u touch the gas pedal, after that it starts and runs fine
Old Jan 2, 2012 | 01:08 AM
Mine runs fine. every once and a while on a cold start it will bounce from 1100 to like 500 then back up to 1100 then back down to 500 and eventually stable out at 900 then drop back to about 800
but EVERY SINGLE TIME after filling up
it will either try to start and stall... or start bounce a few times and stall out. if im pressing like 15% throttle while starting it and hold it there for like 10-15 seconds then let off itll run fine.
so glad i came across this thread
Old Jan 2, 2012 | 01:13 AM
ThexGovenor's Avatar
Its the evap solenoid, i replaced it a week or so ago and the problem is gone. Its also really easy to change on your own, 10 min or so.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
DANRICKARD
Oct 1, 2015 12:08 AM
