Dipstick Popping Out
Old Dec 14, 2008 | 03:20 PM
Grich171's Avatar
PCV vale is prob clogged
Old Dec 14, 2008 | 03:23 PM
Steven Flit's Avatar
where might that be?
I just let about a quart out and revved it up real quick to see if the dipstick would come out and it did again.. ugh...
so thats not it...
Old Dec 14, 2008 | 03:30 PM
FASTECOTEC's Avatar
It pops out when you rev it up too.under no boost?
Bika's Avatar
Fail Less.
owners manual states 6qts. Can provide pictures if anyone doubts.
pcv is on the back of the valve cover. runs across the back and around the valve cover into the intake. I highly doubt thats clogged. If theres a clog, it's either in the manifold port or somewhere in the head.
Old Dec 14, 2008 | 03:40 PM
SloBaLt RiDeR's Avatar
take your supercharger off also, your gonna have oil in there. same thing happened to me, execpt my pistons were fried... tht crank case pressure built becuase of the bypass on our charger didnt let it out and went thru and out the dipstick weres it the weakest part, iam assuming your starts still?
like boost spike. under heavy load
Last edited by SloBaLt RiDeR; Dec 14, 2008 at 03:40 PM. Reason: Automerged Doublepost
Old Dec 14, 2008 | 03:43 PM
thedubsack85's Avatar
Originally Posted by Steven Flit
plz do...
BTW, I just emptied a quart out of my oil system. Had 7 quarts in there, oops... waiting for the oil to come drain back into the pan and I'll check the level again.
then its the big momment to see if it pops out again.. ugh..
well.. positive crankcase ventilation... is the PCV.. this could be the issue.. never herd of it before on these car's..
Grich171's Avatar
i would say check the hose that goes from ur head to the intake and if thats good search for a way to test the valve ... that valve is what releases crank case pressure...im not exactly sure about the whole take off the supercharger thing i have an ss/tc but i would try the easy things first instead of taking that off lol just my 2 cents.
Old Dec 14, 2008 | 03:56 PM
the supercharged has no no oil residue; I CHECKED IT OUT TWICE yesterday
Guess last thing to check is that thing behind the head.
it only pops the dip stick when under load, 7+ PSI
Old Dec 14, 2008 | 03:59 PM
well when it happend to me, i took everything off, there was a puddle of oil sitting in the air intake, and charger had oil splattered. and there is going to be oil over the intake manifold gasket as well. you might as well go turbo get rid of tht charger..
Old Dec 14, 2008 | 04:05 PM
NEXT!!!!!
read the O.P.
compression is fine
intake manifold gasket is fine
the supercharger is fine
the intake was fine
lessening the amount of oil, no go.
All thats left that I can think of is that PVC you guys are talking about. and puting a breather on it.
Old Dec 14, 2008 | 04:12 PM
  #36
Grich171's Avatar
NEXT!!!!!
read the O.P.
compression is fine
the intake was fine
All thats left that I can think of is that PCV you guys are talking about. and puting a breather on it.
where does that hose go to...it looks like the right ones..not familiar with the lsj lol
Old Dec 14, 2008 | 04:18 PM
  #37
goes to the intake
Old Dec 14, 2008 | 04:23 PM
  #38
Grich171's Avatar
yeah tahts it...take that hose off n see if its clogged...also look in the intake pipe where the hose connects to it
Old Dec 14, 2008 | 04:24 PM
  #39
this one
okay ill take a look
Old Dec 14, 2008 | 04:29 PM
  #40
Grich171's Avatar
yeap thats the one
Old Dec 14, 2008 | 04:30 PM
  #41
yeap thats the one
right on, im working on it
I'll take some photos of it in a sec
Old Dec 14, 2008 | 04:32 PM
  #42
nuttzzy's Avatar
woow you guys are on the ball
Old Dec 14, 2008 | 04:38 PM
  #43
well it doesnt looked clogged...
i need to buy one of those filters now... oy...
Old Dec 14, 2008 | 04:39 PM
  #44
Grich171's Avatar
did u try blowing thru it like a straw or you could start the engine keep the side thats connected to the valve cover on and remove the one thats connected to the intake n feel for a vacuum....and on the side of the valve cover if you remove that while its running you should hear a little hissing sound
Old Dec 14, 2008 | 04:44 PM
  #45
k just one sec
Old Dec 14, 2008 | 04:48 PM
  #46
nuttzzy's Avatar
where is the accual valve at??
Old Dec 14, 2008 | 04:57 PM
  #47
k just did a test, intake side is good. air is being sucked in, no clog so far.
gonna measure the diameter really quick and go buy a filter for it.
be back in a hour or so guys.
Last edited by Steven Flit; Dec 14, 2008 at 04:57 PM. Reason: Automerged Doublepost
Old Dec 14, 2008 | 05:00 PM
  #48
1badBlueberrySC's Avatar
It's called excess crankcase pressure....
Old Dec 14, 2008 | 05:01 PM
  #49
Grich171's Avatar
hmm then it cant be that...ive been doin some searching and it seems alot of ppl have had this problem and they are saying something about them coming stock with a certain o ring missing or something in the intake manifold gasket...ide say if your still under warentee take it in and have them check that out...ive seen someone saying theres a sticky for it but i couldnt find it
Old Dec 14, 2008 | 05:03 PM
  #50
intake manifold gasket on my car is the newer style one w/ the rubber oriface.
brb PEP BOYS
