does anyone have this problem?
when you have the a/c on and you pull up to a light or something and it acts like its trying to die when your sapsoed to be idleing?? it will jump from idle to about 1200 or so then fall to about 3 then back up to 12 ect.... then finaly levels out so far i can only tell it does it with the a/c on
Try to see if dealer will reflash computer. Then clean your air filter (if you have CAI--if not, replace air filter), then clean your throttle body and MAF. These things turned my car from barely running to like-new.
PS sorry i got it in the wrong section
Right after I put my intake on, when I shift from drive to park, it will jump to 1,000, then fall to 500, then go where its supposed to be. Did it a lot right after install. Now not so much.
u did unplug battery for 10 min after doing a power mod correct?
if not slap urself, regain consciousness and go do it lol
why u let the computer relearn everything
Last edited by originaladrian; Apr 27, 2008 at 06:15 PM. Reason: Automerged Doublepost
No, I dint, instructions dint mention. I figure that it will learn as I drive it. Its only the GMPP anyway.
