door handle on the inside broken
My door handle on my driver's side stopped working today. I had an accident earlier this week:
https://www.cobaltss.net/forums/lounge-42/now-driver-cobalt-s-193442/
i was hit on my driver's side so i'm hoping these two incidents are related. I can't open my car from inside or outside on the driver's side. It seems as though the handle is loose. Has anyone had their door handle just stop working or do you think it might be accident related? Any help would be appreciated, thank you!
I was in the car too and I had to climb over the passenger's seat to get out. I'll try the spray lubricant and see if that helps fix my problem! Thanks!
it's possible the cable popped out of the handle.... try removing the screw cover behind the handle with a flathead and using a phillips to remove the screw....then gently pry around the handle to pop it out from the door panel.....if the cable is not attached, you'll know....a black piece clips to the top-rear of the handle to hold the cable in place......if it's attached, then you'll probably have to tear into the door to see where the issue lies, but pull on the cable (detached from handle) and see if it opens the door....the cable may be stretched
let me know if you need anything else!
mine did this 2 weeks ago and i was never in an accidient. i climbed in via passenger door (worked) and started playing with the lock and unlock button like i was in a race to hit 1000000 times in less than a minute and boom it fixed it and never happened since than... so go have it at.
ive had the same problem, but mine happens only sometimes and if i bang on the door a little bit it usually fixes itself. lol. or if i pull really hard on the inside handle.
i actually pulled the outside handle so hard that i cracked the plastic base on the little thick piece of plastic that actually pulls the cable. lol.
so that door handle doesnt sit flush anymore.
just got my cobalt have the same problem its F*ckign annoying!!!!!!!!! it seems like a faulty latch, i lubed it and even moved it by hand it seems fine! i dont wanna take off my panel i have no time
it's very easy to fix this stuff. if a car comes into my shop and someone asks me to fix a door handle there's no way in hell it's leaving til it's fixed. and it won't break until someone hits it with a heavy blunt object. sounds like something's broken and the guy half assed it. just pull off the door panel and use some common sense. it;s really easy to figure out how the cables work!
lol. I am just saying it's not hard at all! most of it is common sense and if you can take apart a pen and re-assemble it you can do this too. give it a whirl, the worst that can happen is you gotta bring it to a shop and they'll fix it which is what you wanna do anyway.
I had this problem awhile ago with passenger side door, i searched and its more common than you think...Ultimately someone told me to fix it with WD40 on the part of the door that latches to the car NEVER HAD THE PROBLEM AGAIN...so for those of you that still have this happen off and on just WD40 it, easy fix
mine broke where it holds the cable by chrome plated plasic and if the cable that releases the door is fine just buy the whole inside door handle. the whole thing only costs about $23.00 (for me @ dealership) but you will have to take the door panel off to find out if you have to buy the mounting bracket and screw ( i re-used mine ).
***BTW***
im pretty sure its caused by the power door locks malfunctioning and wear n tear so im just more gentle with it these days, i should'nt of ever bothered with Craigslist and such waiting 2months for a 23 dollar part lol
***BTW***
