drivers side headlight problem
Old Jul 2, 2009 | 09:15 PM
CobaltVenomSS's Avatar
when ever i start my car at night..(i have 8k hids) my left headlight wouldnt turn on..the halos and leds would but not the light itself...so i would turn the lights off then back and they both hids came on just fine and would stay on till the car would be turned off...
well that was then and now my left headlight wont come on at all not even the hi beam...
but if i turn the hi beams on back to lo beams the hids come on but very rarely...same for hi's...
is it bad wiring???
Last edited by CobaltVenomSS; Jul 2, 2009 at 09:15 PM. Reason: Automerged Doublepost
Old Jul 2, 2009 | 09:18 PM
ssyellow's Avatar
I kinda have this prob with my fog. left fog turns on but the right one I have to flip on/off sometimes and then it works.
Old Jul 2, 2009 | 09:20 PM
OneCOLDBIZL272's Avatar
is it bad wiring???
some cobalts have to upgrade a wire on the headlight housing and add a relay, but some dont , 06 are the only year i know you need a relay on. cause i didnt have to do it to my 05 0r 09, nore did my one friend that has a 07 but, i have two other friends that had to and they both owned 06's
Old Jul 2, 2009 | 09:21 PM
it sucks cuz i cant drive at night...one 8k hid isnt to much light lol
so i gotta go to the dealership?? or order a new hid kit?
Last edited by CobaltVenomSS; Jul 2, 2009 at 09:21 PM. Reason: Automerged Doublepost
Old Jul 2, 2009 | 09:24 PM
NWAE Cobalt's Avatar
subd
if your cobalt has the option to pull the drl fuse. pull it it might end your problem... some balts had drl as the headlights, the drl power current isnt the same amount of power as if you had your lights turned on.
Old Jul 2, 2009 | 09:25 PM
isnt that just for 07's???
i got a 05
Old Jul 2, 2009 | 09:31 PM
you shouldnt have to go to the dealer ship, just contact the place where you bought your hids from, they will tell you what wire you have to upgrade or they will sell you a relay kit to add to your car to make them work. try pulling your drl fuse first i have seen that work before for a few people, if you have the option to do that cause you cant on all balts, the fuse is a 10amp red in the fuse box under the hood. if you car has it
i got a 05
07,08,09 have the drl fuse. if you have a late production model 05 you'll need the relay kit i believe. i have a early model 05 ss/sc and i dont have any issues, same with my 09 i didnt need a relay, i would get in contact with the company that makes your ballast and order the relay kit, i had to do it on my malibu and my buddy with a TBSS had to do it also along with the two 06ss balts
Last edited by OneCOLDBIZL272; Jul 2, 2009 at 09:32 PM. Reason: Automerged Doublepost
Old Jul 2, 2009 | 09:32 PM
i got the kit off ebay
Old Jul 2, 2009 | 09:34 PM
contact the seller, my one friend with one of the 06's bought off ebay and he told him how to fix it or what he had to buy and he never had a problem since.
Old Jul 2, 2009 | 09:35 PM
http://cgi.ebay.com/ebaymotors/BI-XE...Q5fAccessories
this is the guy i bought them from
Old Jul 2, 2009 | 09:38 PM
but did ur buddies have their hi beam go out too?
Last edited by CobaltVenomSS; Jul 2, 2009 at 09:38 PM. Reason: Automerged Doublepost
Old Jul 2, 2009 | 09:40 PM
you wont have high beams with that kit.
Old Jul 2, 2009 | 09:50 PM
its high or low from what i under stand from the page, not both, those bulbs look really funny thou weird. do you have the hid filiment and another small bulb next to it
my buddy with the 06 only had low beam hid's cause low beam is hid and the high is not as bright and looks like a drl, and my 05 had the dual beam but, i replace them after i had a low beam fail after 3 years, and just got a low beam cause you'll never use the high beam.
Last edited by OneCOLDBIZL272; Jul 2, 2009 at 09:50 PM. Reason: Automerged Doublepost
Old Jul 2, 2009 | 09:52 PM
noo...i have 1st gen projectors..so i have hid lo beams...and whatever the projectors came with hi beams
Old Jul 2, 2009 | 10:14 PM
your probably need a relay installed
just get in contact with the seller that you bought them he will tell you what you will need to do. just tell him your problem, they will tell you what wire you have to upgrade and and the realy. and were to get it they might even send it to you for free never know.
Last edited by OneCOLDBIZL272; Jul 2, 2009 at 10:14 PM. Reason: Automerged Doublepost
Old Jul 2, 2009 | 10:15 PM
thanks for ur help
Old Jul 2, 2009 | 10:24 PM
no problem
Old Jul 2, 2009 | 10:32 PM
inquisit99's Avatar
I have the same issue with my hids where the right lowbeam doesn't always turn on, on the first try. have to turn em off then back on. lemme know if the relay fixes the problem
Old Jul 11, 2009 | 09:29 AM
cobalt123's Avatar
i have an 06, and have 6k hids but dont have that problem, no relay installed. my hi beam wont turn on but my 2nd gens just eat fuses for breakfast so wtf
Old Jul 12, 2009 | 03:20 AM
Nighthawk243's Avatar
Two things here:
First... put the problematic HID kit into the side that you KNOW to work. Doing this will rule out a bad ballast/bulb.
If the one from the problematic side works fine when swapped, then it is an issue with power delivery on the other side of the vehicle and using a Relay harness should help the issue.
Now if it gives you issues when put in the working side, then it is a bad ballast and should be replaced.
Solaris99
28
Mar 15, 2017 01:22 PM
biniecki
Oct 25, 2015 02:23 PM
dennis69
Oct 20, 2015 04:49 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
Tupp
Sep 30, 2015 08:18 PM
