DTC 1182 and 1183
Old Apr 17, 2007 | 07:44 PM
syP's Avatar
syP
DTC 1182 and 1183
P1182 Supercharger Inlet Pressure Sensor Performance PCM
P1183 Supercharger Inlet Pressure Sensor Circuit Low Voltage PCM
Just installed a set of NGK BRK7e plugs gapped at .45 (or .045 whatever)
The CEL came on after install.. the car is running perfectly fine.. and the CEL is NOT blinking...
I searched already... didnt find out how to fix it.
My car is 8000 miles. And they did put in the Stage 2 reflash.... but it just started today with the CEL after the plug install
*** edit
Is that the sensor on the top of the supercharger??? (near the MAF sensor?)
i guess the guys at the shop thought it would be funny to unplug it while i was away from the Car (installin my plugs at my shop)
Is that what would cause it?
Old Apr 17, 2007 | 11:32 PM
Coblasts's Avatar
Either that or you broke a wire at the connector leaning on it or working a round it.
Not sure where it is but somebody will jump in with the answer.
Old Apr 17, 2007 | 11:41 PM
M88ArRamadi's Avatar
it's the sensor on top of the SC. plug it back in and you'll be fine.
Old Apr 18, 2007 | 02:04 AM
syP's Avatar
syP
Ya i did, and the light went off tonight.. finally... thanks guys
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Dustonian131
Sep 23, 2015 08:03 PM
WopOnTour
Jan 22, 2015 02:08 PM
X3r0
Oct 27, 2010 08:39 PM
Cobaltss/TC
Jul 10, 2008 12:17 AM
