E-Brake not working?
So my E-Brake is no longer working well. I guess it's loose or something but there is not as much tension on it and if im on a hill going up, the e-brake will not hold the car and it will roll backwards slowly. is this an easy fix or more advanced? and if i were to have it done by a shop, would it be an expensive job? any help would be great. thanks!
You can pull your console out and inspect the cable that far and see if there's any fraying or if the latching mechanism may have let go. Sounds to me like it's either snapped, severely stretched, unlatched or in major need of an adjustment.
EDIT:
Here, see if this how-to thread helps you take a look
EDIT:
