E3 plugs destroyed LSJ stage 2!!!
Old Jun 20, 2008 | 12:57 PM
  #51
rnjmur's Avatar
Originally Posted by shabodah
Note to All:
ANY spark plug that has an abnormal amount of terminal hanging out in the combustion chamber in a forced induction engine (especially one running pretty hot with gasoline), is going to basically heat soak the terminals and cause them to act as if they are several stages hotter than the plug actually is. This heat is what causes the porcelain to crack and the parts of the terminal to fall into the cylinder. Extreme drag engines actually have the spark plug terminals design and/or cut to leave as little metal as possible in the area.
Exactly what I was going to say. You should never run multiple ground electrode plugs in FI cars. The electrodes actually retain heat and cause detonation.
Old Jun 20, 2008 | 01:02 PM
  #52
JohnsRallyYellowSS's Avatar
E3 plugs are total ****! I work at advance auto parts and only recommend factory style plugs for the vehicles. ACDelco/NGK=chevrolet, Autolite/Motorcraft=ford, Bosch=BMW, Champion=Chrysler etc....
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
DarrenGC
Dec 24, 2021 01:55 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
