Eating starters. Why?
Car: Cobalst SS/SC 2007
Installed before problem: OTTP stage 2 kit/ottp heat exchanger/dual pass endplate/hpt tune.
Problem Description: We put the new tune in and tried to crank it. It sounded normal but would not turn over. After a couple tried we heard a horrid metal on metal grind. The starter was shattered. We replaced the starter and tried again. Exact same thing happened.
Question: What could be shattering the starter?
U have a bad ground buddd...stop crancking too much u gonna chocke the engine with gas...oh yeah ur cat will prolly be clogged pretty bad afterwards and if ur catless prepare for a big backfire when it cranks on if u keep on crancking and nothing happens
happened to me haha...
Flash back to stock, repeat. Starts don't magically break by themselves on a 2.0 liter engine. If you flash a new tune and suddenly it won't crank the tune is at fault, probably severe pre ignition making the starter fight the engine or backlashing the motor, which ruins gear drive starters.
Posted the tune under V4 engine tuning forum. It is titled "Eating Starters"
In accessories mode the following show
tps = 36%
map = 96
tps = 36%
map = 96
