ebrake problem!
ebrake problem!
i pull the ebrake and if i am on a hill the car will drift backwards bad not just creep its a steady roll....... how to fiix?
bump anyone
bump anyone
Last edited by purplehaze03; Jul 13, 2009 at 08:39 PM. Reason: Automerged Doublepost
If you slide of the cover (there is a tab deal on the underside) you should see a nut you can tighten. I'm not sure what size but it is pretty small. Tightening this should snug up the ebrake. If the problems persists, I'd take a damn close look at your rear brakes. Best of luck to ya!
