engine noise
Old Mar 24, 2007 | 06:57 PM
gotboost21's Avatar
engine noise
I just recently purchased an 05 cobalt ss/sc and I have noticed some kind of rattling noise coming from the valve cover area of the engine. i was wondering if these 2.0 sc engines are known to be noisy or if this is something I should be concerned about.
Old Mar 24, 2007 | 07:00 PM
djcasper_bpm's Avatar
i get that sometimes too. have no idea what it is..
Old Mar 24, 2007 | 07:04 PM
gotboost21's Avatar
I only have 3k on mine how many miles on yours
Old Mar 24, 2007 | 07:09 PM
just over 10,000 miles.. i only get it every so often, and only at idle.. its like a clicking tappet or something.. i cant figure it out. and when it does happen i head to the dealership. by the time i get there it stops and i look like an ass when trying to explain it to the grease monkey..
Old Mar 24, 2007 | 07:16 PM
rnjmur's Avatar
This can be 1 of 2 things:
1. The timing chain. Our cars can have some noisy timing chains.
2. The supercharger. Sometimes my SC will make a rattling noise on start up. After a minute or two it warms up and the noise goies away. The Eaton SC can be noisy at idle sometimes.
Old Mar 24, 2007 | 07:37 PM
gotboost21's Avatar
so do you suggest i be nervous about the noise?
Old Mar 24, 2007 | 07:43 PM
it doesnt really bother me.. these engines do make some noise..
Old Mar 24, 2007 | 07:45 PM
gotboost21's Avatar
aight i jus don't want my car to freakin blow up right after I got it, ya know. Thanx for the input
Old Mar 24, 2007 | 07:47 PM
it wont blow up.. it made me nervous the first few times i heard it.. but never had any problems,,,
Old Mar 24, 2007 | 07:53 PM
rnjmur's Avatar
I wouldn't worry about it unless the noise doesn't go away, or unless the noise gets worse. If you start hearing the noise ALL the time, then there might be a problem. But for the most part I wouldn't worry about it.
Old Mar 24, 2007 | 09:22 PM
Halfcent's Avatar
I'm old school
The Ecotec valvetrain is VERY noisy. It is normal. It's a result of the timing chain meshing the gears. And at idle, the cams tap a bit. Perfectly normal.
biniecki
Oct 25, 2015 02:23 PM
jimbofug007
Oct 2, 2015 12:06 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
DANRICKARD
Oct 1, 2015 12:08 AM
