Engine Power Reduced
Old Oct 12, 2010 | 05:50 PM
06SS ALL DAY's Avatar
So while getting on the highway this afternoon my engine light came on and Engine Power was Reduced, went to my friends shop hooked up the obd and it said something about the voltage going to the Throttle Position Sensor.... so we cleared the code, everything was fine and obviously after the systems relearned etc... it happened again. would my N2MB WOT Box cause this problem? it is hooked up to the TPS and ignition. i never had this problem and it has been installed in the car for over a year give or take a month. or does my TPS really have to be replaced. i looked at the wires for the wot box and they all seem to be ship shape. no burning or corrosion. they were all properly secured, covered and connected... i'm going to replace the TPS n see if that works. but i have never heard of our TPS's going bad. any insight is welcome. thanks
Old Oct 12, 2010 | 06:20 PM
This was the code: P0122 Throttle Position (TP) Sensor 1 Circuit Low Voltage ECM, PCM
so i can only assume that the N2MB is causing this problem. i'm going to email them and see if they can send me a new box or something
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
ernnyyes
Oct 2, 2015 05:16 PM
SSLOW06
Oct 1, 2015 07:21 PM
Stuff
Oct 1, 2015 05:47 PM
patooyee
Oct 1, 2015 01:07 PM
