Engine power reduced again! Help please!
Old Jul 28, 2011 | 05:51 PM
SSCobalt~SSZ24's Avatar
Angry Engine power reduced again! Help please!
Ok here is the story. About 3 months ago I was having the engine power reduced problems constantly. Drove with the air box mod for 3 years so I bought a really clean used MAF sensor and changed the air filter. It has ran great ever since. Now out of nowhere it is doing it again and does it 10 times as much when my AC is on. I have to be easy on the throttle because once I give it a tiny bit of gas it goes into limp mode. Just ran a cheap scanner on it and got a MAF throttle posistion correlation code a system to lean code and a Bank 1 sensor 1 O2 sensor code. Also got this weird code. P1182 which is a DTC code. Also when it is running and doesnt go into limp mode it if I hammer it, it has **** for power and over 5k rpms it feels like something is holding it back. Any ideas?
btw its a 06 LSJ
Old Jul 28, 2011 | 06:06 PM
Any advice guys?
Old Jul 28, 2011 | 06:07 PM
JerCatt's Avatar
Canada
Not to sure if this will help but my car got reduced engine power once so I immediately took it to GM they did some tests then they replaced the catalytic converter for free. It was under warranty. Havent had any problems since.
Old Jul 28, 2011 | 06:09 PM
I dont have a cat. But thanks!
Old Jul 28, 2011 | 06:19 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Replace your Throttle Body.
Old Jul 28, 2011 | 06:26 PM
dannysauer's Avatar
Check the vac lines pull them off and make sure they r not broke anywhere and clean the tb
Old Jul 28, 2011 | 07:23 PM
throttle body huh? makes sense. ill do that. thanks guys
Old Sep 18, 2012 | 01:56 PM
NinjaHampster's Avatar
did this work? i am currently having the same issues and i dont have a cat as well
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
ernnyyes
Oct 2, 2015 05:16 PM
SSLOW06
Oct 1, 2015 07:21 PM
Stuff
Oct 1, 2015 05:47 PM
patooyee
Oct 1, 2015 01:07 PM
