"engine pwr reduced"
Old Apr 27, 2013 | 11:45 PM
Tcobalt421's Avatar
hey guys,
so today i swapped my hvac and put blue 3mm leds in it. During the process, I blew the fuse, which lights the hvac, both mine and my passenger switches, the steering wheel, and the lights on the gear box( P, D, N, R, etc). so pulled the fuse box and swapped the fuse presto problem fixed, go to turn the car on boom, "engine power reduced, car starts right up everytime and cuts almost instantly off. I cant get it to run more than a second. Disconnected the battery a few times for 25 mins at a time and still comes right back on and same problem...Any suggestions? i mneed the car asap to get back and forth from school and work. Thanks any help would be greatly appreciated
Old Apr 28, 2013 | 09:47 AM
Tcobalt421's Avatar
bump anyone?? help is greatly appreciated!?
Old Apr 28, 2013 | 09:54 AM
G5GT2007's Avatar
try checking some of the fuses under the hood may have blown one of them as well.
Old Apr 28, 2013 | 09:59 AM
BankerBalt's Avatar
since it blew your power steering, that would be the power reduced reason. but the code probably just needs to be reset.
Tcobalt421's Avatar
did do that, you think it was one of the bigger, gray looking fuses that powers the crank or somehing? how do i tell if those bigger fuses are blown?
Old Apr 28, 2013 | 10:02 AM
G5GT2007's Avatar
shake them and see if you hear something rattling inside them. that is normally how you can tell they are bad.
Old Apr 28, 2013 | 10:06 AM
BankerBalt's Avatar
also, they're relays, not fuses.
Old Apr 28, 2013 | 10:07 AM
Tcobalt421's Avatar
okay im going to check those relays now thnks
Old Apr 28, 2013 | 10:14 AM
Tcobalt421's Avatar
checked all the relays, nothing is blown just that one 15a parking relay which i replaced last night
Last edited by Tcobalt421; Apr 28, 2013 at 10:14 AM. Reason: Automerged Doublepost
Old Apr 28, 2013 | 10:21 AM
BankerBalt's Avatar
what codes are you throwing...
Old Apr 28, 2013 | 04:35 PM
Tcobalt421's Avatar
Not sure yet waiting on my friend to come by with the code reader from auto zone ASAP
Old Apr 28, 2013 | 06:25 PM
Tcobalt421's Avatar
Throwing codes
P0689
P1682
P2101
P2176
P0689
Old Apr 28, 2013 | 08:43 PM
Tcobalt421's Avatar
bump anyone? and yes i know some of the codes are for the 02 sensor and cat dont worry about those that is another issues already taken care of, any help would bew appreciated! im having it towed to the mechanic tomorrow morning!
Old May 3, 2013 | 01:14 AM
droponikz's Avatar
I had an engine power reduced light that would come on every once in a while, then gradually got worse so i finally took it to the dealership, and i guess some of my wiring harnesses were chewed up right in front of my supercharger. So check those out cuz that solved my problem.
HEATON
Oct 16, 2015 07:21 PM
ernnyyes
Oct 2, 2015 05:16 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
DocSvensk
Sep 27, 2015 02:24 PM
