Engine Rattle
Engine Rattle
My engine has just recently started a rattling sound in the last couple of times that I have driven it. My car was purchased with minor front-end damage, so I believe that all warranties would be void, though it only has 59,xxx miles and all maintenance has always been done on time. I found an older thread on the site with a video that matches my sound, but there was no specific answer, and I didn't want to bump the old thread.
This is the video from the thread. Again, this is not my car, but what it sounds like. The oil was just changed after this was noticed with no change to the sound:
Any help or suggestions would be appreciated, thanks!
Before I go further can someone else chip in here to confirm its the tensioner?
Confirmed. Some people just take it out and put the new one in real fast (10-30 minutes). Personally, I would take the valve cover off to confirm it didn't jump any teeth when replacing the tensioner.
It shouldn't take a shop long at all, considering it took me about an hour and I was going slow. At zzperformance.com they have the "upgraded" tensioner that you could buy for your mechanic to install if you wanted a better part.
Edit, just noticed you were from Maine too! haha
And wow, I didn't realize you were from Maine until now too. Are ya up North?
I went the longer way, all you do is remove the valve cover, zip-tie the timing chain, remove the old tensioner, put the new one in, and tap or gently hit the end of the new tensioner once installed to release it.
I am located about an hour North of Bangor, so I am fairly far up here, haha
Take a long flathead screwdriver and place it on the supercharger, on the valve cover, and anywhere else you think the sound may be coming from, and then put your ear up to the handle. It'll be pretty evident what the problem is.
BoSStwick: When you changed yours was the sound coming from the entire timing chain area or just one specific area?
The sound is definitely coming from the left side of the engine (timing chain area), I was mostly trying to determine what component is the culprit causing the sound.
I remember the sound was somewhat hard to centralize, but it was generally around the timing chain area. If you put your hand to the far left of the valve cover right where the gears are you should be able to feel the chain hitting the top of the valve cover (or at least that's how bad it was for me).
you do want to make sure that the black chain guide is not broken or damaged in anyway. I would replace the tensioner and if the noise goes away, good, and if it doesnt, explore further. Good luck.
Got the new style tensioner in the mail today, took about 5 minutes to change. Running perfect and no more loud obnoxious rattling coming from the left side of the engine now. Thanks for everyone's help
patooyee
Oct 1, 2015 01:07 PM
