esc help
Old Jan 27, 2012 | 12:24 PM
fergieface's Avatar
esc help
I was picking up a buddy the other day and as I was pulling out of the driveway the car shuddered for about 2 or 3 seconds. Then it felt like something released the shuddering stopped and SERVICE ESC came on in my DIC. Since then the SERVICE ESC is always present. When I got home I did some research and found that common problems with the ESC can be low brake fluid or bad wheel speed sensor in the hub. I checked my brake fluid first, not the issue, its at the max fill line. The other I haven't checked for two reasons, first I don't know how to and second I don't see how it would make the vehicle shudder like it did. Any ideas or help would be greatly appreciated.
Old Jan 27, 2012 | 01:39 PM
Chevrolet Cust Svc's Avatar
As this light indicates that your electronic stability control needs to be serviced, I would recommend visiting a dealership for further diagnosis. What year is your vehicle?
Sarah
GM Customer Service
Old Jan 27, 2012 | 01:46 PM
rogersj's Avatar
defently can make your car shutter
Old Jan 28, 2012 | 09:18 AM
fergieface's Avatar
It's a 2008
Old Jan 28, 2012 | 10:15 AM
guitarenvy's Avatar
Let the dealer diagnose it, there are hundreds of possible service ESC causes.
It sounded like you might have had a misfire, not enough to turn the SES on but enough for the PCM to disable your ESC system as it will not be able to function properly with a misfiring engine.
vahdyx
22
Dec 18, 2010 03:26 PM
rukkee
Nov 28, 2010 02:06 PM
CordiaDOHC
Tuning
Mar 25, 2010 07:40 PM
steven6870
Jan 28, 2009 10:21 AM
