Exhaust leak?? Please help!!!!
Old Jun 14, 2010 | 08:28 PM
brendidero's Avatar
I bought my car used about 3 months ago, it has just over 61,000 km on it. The first thing I noticed when I was driving it home was a clicking/ticking noise coming from the RF under acceleration. Since then it seems like it may becoming worse, or it may just be the fact I have my windows open and can hear it better now. I went under the car with it running and could not see anything, it does not make the noise when ideling or when off the throttle or under vacuum. Does anyone have any ideas...Again, main problem is a ticking/clicking noise coming from what sounds like the RF when on the throttle. Thanks!
Forgot to ask, are these normal sounds or a problem?
Last edited by brendidero; Jun 14, 2010 at 08:28 PM. Reason: Automerged Doublepost
Old Jun 14, 2010 | 08:30 PM
EdCobaltSS's Avatar
same problem on mine, its the flex pipe in the downpipe
user 70823082's Avatar
Idk what that has to do with an Exhaust leak, but what year is the car?
Old Jun 14, 2010 | 08:34 PM
brendidero's Avatar
It's a 2006, I'm going to take it over my pit tomrrow and have someone rev it up...check the flex pipe for leaks. Is there any easy fix for it or do I have to replace the entire section? I'm still open to other opinions on what it might be.
Old Jun 14, 2010 | 09:00 PM
EdCobaltSS's Avatar
pretty sure there is no repair, just replacing downpipe
Old Jun 14, 2010 | 09:17 PM
brett5's Avatar
do you have limited slip the locking will make a clicking noise
Old Jun 14, 2010 | 09:27 PM
brendidero's Avatar
Exclamation
No, this is definetely exhaust, mabey drivetrain...only is heard and get louder as throttle input increases. I am looking for downpipes does anyone know of any other aftermarket cobalt performance parts manufacturers. I know of zzp, any else?
Old Jun 14, 2010 | 09:43 PM
EdCobaltSS's Avatar
check the supporting vendors list under classifieds for a list
Old Jun 16, 2010 | 05:14 PM
brendidero's Avatar
Exclamation
So I brought my car over our pit today at work, went underneath and could not hear anything of any exhaust leak. Had someone hold it at 4000 and still nothing...all I could see is mabey the flex pipe or cat chirping a bit. I took my shop foreman out, he says its a normal sound for a four cylinder. Dunno what to think, I have never heard another one so its hard to base an opinion.
Old Jun 16, 2010 | 05:17 PM
springerdesigner's Avatar
Same problem here. I have an aftermarket ZZP midlength header/downpipe combo. Sounds like it's coming from around this section. I've taken it to exhaust shops and they can't find anything work with it. It's SUPER annoying and I wish I knew how to fix. Good luck.
Old Jun 16, 2010 | 05:44 PM
brendidero's Avatar
Does your zzp header/downpipe use a cat? I was starting to think it may be coming from inside the cat. It's a hard diagnose, it seems to only make the noise when the engine is making boost, under vacuum it seems fine. Like I said, I had someone hold it at 4000 and with my head right next to the flex and cat could not hear the same noise as when going down the road.
Old Jun 16, 2010 | 05:51 PM
blackss2.0's Avatar
definitely flex pipe. Chevy replaced my down pipe under warranty but than the flex pipe broke again five thousand miles later so I just put a zzp catless down pipe in yesterday. The flex pipe is **** on the stock down pipe.
Old Jun 16, 2010 | 06:41 PM
Yes. Mine has a magnaflow hi-flo cat on it. Shops checked it and SAID it wasn't clogged.
BTW... I'm a 2.2 and I haz no boost...
Old Jun 16, 2010 | 06:44 PM
SSMOKEM's Avatar
It's common, like stated it's the flexpipe.
Old Jun 16, 2010 | 11:19 PM
EdCobaltSS's Avatar
i keep tellin you man flex pipe
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
tomj77
Oct 4, 2015 11:39 AM
