Exhaust Problem... Any Ideas?
Old Feb 19, 2011 | 11:05 AM
Soulflyz's Avatar
Hello,
I have a problem and just wanting to know if anyone has any answers…
I have an after market downpipe and magnaflow exhaust…
The installers that put it on must have done a hack job because the link between the two items are failing…
Failing you say? Yah the links between the bolts have bent open and now leaking exhaust… Badly…
I have taken this to 2 exhaust shops and have said that if I can bring in the link they can weld it in but have
no clue where to find it… any ideas or help?
Thanks guys
Old Feb 19, 2011 | 01:29 PM
06cobalt racer's Avatar
are you talking about the flanges or the hangers?? can you post a picture of what your talking about?
Old Feb 19, 2011 | 02:09 PM
Soulflyz's Avatar
My apology’s no I am not able to post pictures…
But from what I was told by the mechanic it is the flange..
I will see if i can find pics online.
Old Feb 19, 2011 | 02:23 PM
Soulflyz's Avatar
There i think this is a better pic..
The 3 bolt connecter has bent open on both sides. Is that possible to fix? or do i have to replace the hole header/DP?
Also my Connecter (flange?) only has 2 bolts on it.
Thanks
Old Feb 19, 2011 | 02:45 PM
they bent the 3 bolt flange??? the circled parts below?? wow no idea how they did that..
check here.... Cobalt & Ion ---> ZZ Performance
they have the 3 bolt lsj flange. it is 35 each so if they meesed up both you will need 2.
[IMG][/IMG]
Old Feb 19, 2011 | 02:56 PM
Soulflyz's Avatar
No thats the best pic i could get i have a 2 bolt flange...
They did not bend it my car did after a day at the track...
Thanks for the help i will look at the web site...
Old Feb 19, 2011 | 03:07 PM
Soulflyz's Avatar
From what the pic shows the flange a "washer" like thing that goes between the 2 pipes?
If so the 2 pipes where they are bolted together is acutualy bent.
I'm at work so resorcest are limited.
Old Feb 19, 2011 | 04:11 PM
what header and downpipe do you have?
Old Feb 19, 2011 | 04:27 PM
Soulflyz's Avatar
thats the problem i know its after market because it dont have the cat, but it was on the car when i purchased it.
Old Feb 19, 2011 | 04:33 PM
c1_c1rca's Avatar
your car bent the flange after a day at the track?? you hit something? also where did u take your car? if it was the gm dealership on geatz and 32nd id recommend taking it somewhere else, they charged me over $500 to replace my studs when they snapped 2 years ago
Old Feb 19, 2011 | 04:35 PM
can you take a pic of it and e-mail it to me? jonnyc127@yahoo.com
Old Feb 19, 2011 | 04:41 PM
Soulflyz's Avatar
I bent it at the track last summer, but over this winter it has opened up to a point i can stick my fingers in the hole.
I took it to light speed innovations they sent me to south hill muffler. South hill is sending me to ho performance... after 2 charges with no work done i want to get more info to see if it is even posible to fix or just replace...
Old Feb 19, 2011 | 09:25 PM
rukkee's Avatar
The exhaust shouldn't be rigid enough to allow the kind of force it would take to bent that flange without moving the whole system . Between the flexpipe and the rubber hangers .... it should give before bending . Are you sure you didn't hit something ....or that it didn't line up perfect and the installers bent the ears trying to suck it together ? I guess a picture would explain alot..... good luck thou , hope u get it sorted out.
EDIT.... Ok ... wait .... it's bent were the DP meets the header ? Or the the dp meets the catback? This has me confused cause ive never seen a header to dp connection that is only 2 bolt.
Old Feb 22, 2011 | 11:22 PM
Soulflyz's Avatar
I will work on getting a pic soon... But from what Light speed said the installer did a shitty job on installing it that is why i bent over time.
06MetallicBalt
Jul 20, 2025 08:47 PM
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
Oct 20, 2015 09:56 PM
DANRICKARD
Oct 1, 2015 12:08 AM
