a/f gauge malfunctioning
Old Sep 24, 2011 | 08:58 PM
JustACobalt's Avatar
i have a digital a/f gauge in my 2009 ss/tc and about two months ago it started to malfunction and im not sure what is causing it. when i first start driving, it reads fine but after usually a 1/2 to a mile of driving it goes to 20.0 for a second then 50.2 and stays around 50.2-50.3. i read that dirty o2 sensors are uncommon but i dont understand why it works initially then starts to malfunction. it seems to happen quicker under harder acceleration also, if i drive very conservatively it can work for longer. any ideas? its important for me to track my a/f ratio while i drive because i believe i have a vacuum leak somewhere
Old Sep 24, 2011 | 09:15 PM
drumrush's Avatar
what is the brand? i know some like my innovate lc-1 need to be calibrated every so often
Old Sep 24, 2011 | 09:25 PM
not sure of the brand, but its a very simple gauge. its rectangular in shape and has just a digital readout only. nothing fancy like a lc-1
Old Sep 24, 2011 | 09:32 PM
drumrush's Avatar
oh i dont know then. it could be a bad sensor though, but id wait for some more feedback from others before you drop 70 bucks on a new sensor
Old Sep 24, 2011 | 11:39 PM
yep, i hope somebody chimes in. thanks for the help tho
Old Sep 25, 2011 | 10:01 AM
Coblasts's Avatar
Check the connection to the sensor first for water intrusion ,corrosion etc and apply some dielectric silicon to them for protection.
They work on such low voltage any change in resistance could affect it.
But it does sound like the sensor is buggered or contaminated with crap.Im not sure what you could clean it with or if you can at all.
Pull it out and take alook.
Old Sep 25, 2011 | 10:16 AM
FrossB's Avatar
Thread Killer
I have an AEM wideband and it kinda does the same thing. It will bounce back and forth between its highest and lowest reading constantly. Im thinkin bad sensor but im going to check all the connections too.
Another possibility for me anyway is the that my wideband bung is right in line with my 2nd O2 sensor about 4 inches behind it so there maybe be some "turbulence" causing it to read wrong.
Old Sep 25, 2011 | 10:44 AM
RooTBeeR's Avatar
ngk powerdex afx also needs calibration, but it only reads 9-16 so i think you have something else
this one?
Old Sep 27, 2011 | 12:19 AM
alright ill have to take a look. and rootbeer, its similar to that but its smaller
Old Sep 27, 2011 | 12:22 AM
rcarr0327's Avatar
I have an aem wideband gauge and for the longest time my would work then after a while of driving like 10 minutes it would just crap out and sit 14.7... eventually it just stopped working all together and sat at 14.7 all the time. I picked up a new sensor and popped it in and it works now, maybe same type of deal. sensor going bad
Old Sep 27, 2011 | 12:34 AM
nizzle's Avatar
I just installed mine (AEM) a few days ago. And brand new right out of the box it bounces around a lot. Under normal driving/cruising it constantly bounces between 12.5 and 15.5 but when I lay into the accelerator the reading drops to 10. IDK if it's supposed to be like that or what
Old Sep 27, 2011 | 08:57 AM
rcarr0327's Avatar
yea ur sensor is fine if thats what ur asking.. i assume ur N/A with mods and not tuned? thats why ur running really rich when you gun it. usually when ur at crusing speeds ur AFR should bounce around but 12.5 is a little rich but nothing u cant fix with a tune
Old Sep 27, 2011 | 11:02 AM
nizzle's Avatar
I have TVS, header + full exhaust, dual pass + opt b, 80 lbs inj, trifecta tune, and a bunch of other stuff but basically no not stock
Old Sep 27, 2011 | 11:43 AM
RooTBeeR's Avatar
Yes that's normal, the car is trying its best to stay @ 14.7 so it tends to bounce rich-lean while cruising
Old Sep 27, 2011 | 01:02 PM
rcarr0327's Avatar
yea its normal
Old Sep 27, 2011 | 01:37 PM
nizzle's Avatar
cool! Thanks guys
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
z28addiction
Sep 28, 2015 12:03 AM
Sep 27, 2015 08:53 PM
