Few issues I'm having...
Old Nov 25, 2013 | 09:17 PM
seeyaass's Avatar
Some history first... 2010 sstc.. Fully bolted and tuned. Eibach sport lines on stock struts.
First - I'm getting a pretty strong pull to the right when driving. I had just changed from coils to stock struts with springs... Got an alignment and new tires... Still pulls to the right. Under WOT it's all over the road. Kinda scary.. When I was changing my suspension and connecting the swaybar to the end links, I bolted one up, it was fine when I went to do the right side, it was real hard to get connected to the end link... Could this have something to do with it?
Second- my traction control light stays on constantly, and the traction control button doesn't work.. In dash says service esc. I had changed all wheel bearings prior. It's drivin me nuts. Where do I start?
Any help is appreciated !!
Old Nov 25, 2013 | 09:41 PM
seeyaass's Avatar
Any help at all would be greatly Appreciated !
Old Nov 25, 2013 | 11:34 PM
tomj77's Avatar
most likely ur abs sensors are shot or u didn't plug em back in. if they are not working, nither does ur traction control system and the light would come on. check if u plugged em in. and its a good thing to silicon the back of the plug where the wires go into the plug. my traction control system always screwed up when those got wet, and I burned out a few sensors, till I siliconed those and it never happened again
Old Nov 25, 2013 | 11:38 PM
andrewcarr1993's Avatar
What have you done with your control arms, if nothing then you need to put new bushings in them, mine were moving around quite badly until I bought a set of bushings when I went to Powells shop. Moog solid bushings also work but their eventually going to break unlike the Powell bushings, at the same time though his bushings are around 4x the price.
Old Nov 26, 2013 | 05:20 PM
seeyaass's Avatar
Well I changed them trying to troubleshoot the problem. The button doesn't do anything when I press it. I might just bring it chevy cause I can't figure it out.
Old Nov 26, 2013 | 05:23 PM
seeyaass's Avatar
Cool
I had changed one awhile ago. Like last year. This pulling had happened after I changed my suspension back to struts and springs..
The thing I said about my swaybar, could that have anything to do with it?
Old Nov 26, 2013 | 06:51 PM
tomj77's Avatar
if the sensors are shot then the button wont do anything, it doesn't do anything unless everything is working.
Old Nov 26, 2013 | 08:45 PM
seeyaass's Avatar
ABS sensors are in the hubs correct? I had changed them all not long ago. Someone told me speed sensors, those in the hubs also? Could it be anything else or it all lies in the hubs?
Old Nov 27, 2013 | 01:32 PM
tomj77's Avatar
I think they are the same sensor
Old Nov 27, 2013 | 04:47 PM
seeyaass's Avatar
Okay bro thanks
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
