Fixed Map Sensor and still having problems.
Old Dec 8, 2008 | 05:14 PM
marioc89's Avatar
Don;t mean to double post but I noticed at the last minute that no one visited that thread for a while and I need this rectified like asap so that I could get my car inspected. I'm having problems with my CEL coming on. I took it to Autozone to diagnose the problem and fixed it. What it came out to be was a MAP sensor fualty. After installing a new one, I erased the codes, drove around a while and it came back on. Brought it back to AZ and they ran the diagostics again and came back the same thing. Any idea on what could be causing my problems and how can I fix it?
Old Dec 9, 2008 | 04:25 PM
marioc89's Avatar
The code to my problem is: P0106. I fixed the problem by replacing the map sensor and I reseted and it's still popping the code, same one. So I'm looking for any suggestions from you guys on what to do. Someone please help!
Old Dec 9, 2008 | 04:40 PM
light'bolt's Avatar
next check would be the wiring. check for loose or broken wires.
Old Dec 9, 2008 | 05:06 PM
Halfcent's Avatar
I'm old school
Is the engine actually running okay? Besides for the CEL, do you have any other symptoms?
Old Dec 9, 2008 | 07:05 PM
marioc89's Avatar
The engine is running great and I don't see any brolken wires...at all. I'm just lost here!
Old Dec 10, 2008 | 12:12 AM
Dainslaif's Avatar
Possibly got a bad sensor from the store? Did you replace it with OEM or a generic AZ part?
Old Dec 10, 2008 | 09:56 AM
marioc89's Avatar
It's from AZ. I went back to see if I could get another one and they told me they couldn't do it, which I thought was bs cuz it's under warranty. They should give me another anyway, right?
Old Dec 10, 2008 | 09:59 AM
stenguyen1's Avatar
yea they should exchange it for a new one. cuz my car threw the same code than i replace my map sensor n i haven't gotten a code yet.
Old Dec 10, 2008 | 12:10 PM
Halfcent's Avatar
I'm old school
Ya know, I totally forgot to ask my standard question first!
Is the car still under warranty? And if so, why are you messing with it?
I will assume it is not, and my next suggestion is...
Return the Autozone part completely. Put it back in the box and go get your money back. Put your stock part back in. Check the harness (again), this time looking closely at the plugs and terminals for any indication of arcing. Then if you still have a problem, go get a GM replacement MAP and try that.
Old Dec 10, 2008 | 04:07 PM
Dainslaif's Avatar
As I recall, our car is extremely sensitive when it comes to the sensors, so much so that the generic ones found at Autozone generally throw codes with our car.
Old Dec 10, 2008 | 07:04 PM
marioc89's Avatar
Oooh ok! Let me try that and see, then I'll post back.
Old Dec 16, 2008 | 10:46 AM
marioc89's Avatar
I think you may be right Dainslaif because I went got a nother sensor from AZ and it's throwing the code again. Does this mean I have to get a sensor from from Chevy now?
Old Dec 16, 2008 | 11:55 AM
Halfcent's Avatar
I'm old school
I believe we told you to that the first time. Return the AZ part, don't replace it. Then go get a GM part.
Old Dec 16, 2008 | 10:53 PM
marioc89's Avatar
Well, I wanted to give it the benefit of the doubt and just rule it out. So now that I did that, I'll replace it with a ginwine GM part.
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
dieGone
Oct 1, 2015 06:27 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
jmelton327
Sep 26, 2015 10:04 PM
