Flickering HIDs
Old May 21, 2008 | 06:59 AM
Jesse_Chouinard's Avatar
Flickering HIDs
I put 6000K HIDs into my projectors yesterday and both bulbs flicker....they don't fully turn off then on but you can notice a slight flicker. I know usually on start up they will flicker untill voltage stabilizes but i went for a half hour ride yesterday and they flickered the whole time. So my question is : Will a relay harness help at all? On my 9007 hid kit there was a relay harness and it never flickered. Thanks in advance
Old May 21, 2008 | 09:31 AM
CCBalla10's Avatar
hmmm that's weird...mine only flicker when my seat belt warning starts beeping at me. But another odd thing about mine is when they are on, the radio gets static like crazy.
Old May 25, 2008 | 02:55 AM
Angel's Avatar
Re: HID lights flickering
For the record I am a mobile electronics certified professional. I have a 2007 Cobalt with HID's all around including the fog lamps. What you need to do to get rid of the flickering is relay trigger the low and high beams. What is happening is that you are trying to turn the ballasts on with too low of current from the factory set up whereas it would work fine for factory bulbs but not HID conversion kits.
Old May 25, 2008 | 09:42 AM
Awesome, Thanks. I ordered a relay harness last week. I hope it ends up being that.
Old May 25, 2008 | 09:57 AM
Brian MP5T's Avatar
Drl .
Old May 25, 2008 | 10:00 AM
originaladrian's Avatar
do u have 35 or 55W ballasts?
Old May 25, 2008 | 10:03 AM
35 Watt
Old May 25, 2008 | 10:15 AM
prob a bad ground. i would hook a a volt meter and make sure ur not fluctuating,
it also might just be ur cutoff line and u think its flickering. when u look at the HIDs with ur car still do they flicker?
edit-u dont have a cutoff line, there in sotckers
Old May 25, 2008 | 10:27 AM
no, I have had projectors for 2 weeks now. The light flickers slightly even when the car is stopped.
Old May 25, 2008 | 10:28 AM
to make sure ur not just thinking its ur cutoff line, and to isolate the problem stand infront of ur car and look at ur HIDs at eye level, have a friend rev ur car. post bak if they flicker
Old May 25, 2008 | 03:57 PM
Yep, they flicker. My other kit that I had used a relay harness and I had no flicker, This one doesnt have a relay so Ill try with that first. hopefully it'll work!
SSnRXP
Dec 4, 2015 11:02 PM
chefhhr
Oct 26, 2015 10:36 PM
allpro666
Oct 6, 2015 08:11 PM
dieGone
Sep 23, 2015 10:20 AM
717ssbalt
Sep 2, 2015 10:49 PM
