Fog Light Issue
Old Jan 6, 2012 | 10:30 AM
07SSYellow's Avatar
Resident Post Whore/Troll
Fog Light Issue
ok so i have had an HID kit in my fogs for about 8-9 months now, they worked great, until recently they stopped working, so i investigated a little bit and realized they blew the fuse, so i put a new one in, then turn them back on, driver one lights up, passenger one doesnt, then it blows another fuse....hmmmm so i put a 30amp fuse in it instead of the 20 it requires, same thing but this time the passenger one works and the driver one doesnt! then it blows the 30amp fuse too! i have tried switching the ballasts around and same issue.....
Just wondering if anyone knows how i might be able to trace this problem down or were to go next before i take it to the dealership.
Thanks for the help.
Joe
Old Jan 6, 2012 | 11:04 AM
Gremlin85's Avatar
Hmmm...
So they stay on for a little while and then blow the fuse??
Stop adding bigger fuses, that'll lead to more problems.
It sounds like it's drawing too much current and the first thing that pops to mind is bad grounds. I'd check your grounds and make sure they are clean of rust and corrosion first. If you see any of that at all sand it down with some 400 grit sand paper and then reattach the grounds. Also, check the whole wiring harness for the HID's to make sure they are not chaffing on anything and shorting out. Check the connectors for corrosion as well. Lastly, take the bulbs out and check for corrosion there too. Clean every connection with good electrical cleaner.
Old Jan 6, 2012 | 11:28 AM
rogersj's Avatar
^ x2 theres a short somewhere
Old Jan 6, 2012 | 11:35 AM
07SSYellow's Avatar
there are no grounds for them, there just a plug and play kit lol, but i will check all the connections again today when i rip it apart, im hoping that there is just a loose wire somewere that will be easily fixed.
Thanks John i really appreciate it
Old Jan 6, 2012 | 11:56 AM
TommyP's Avatar
AWD > FWD
Never EVER just add a bigger fuse.
Take your connections apart and check them, they could be corroded
Old Jan 6, 2012 | 12:37 PM
07SSYellow's Avatar
i know lol but it popped the 20amp fuse so all i had left was a 30amp so i just slapped it in there and it popped it too
Old Jan 6, 2012 | 01:12 PM
soundjunky's Avatar
Originally Posted by 07SSYellow
there are no grounds for them, there just a plug and play kit ...
no, the ground in the wiring ~ I think the grounds for the lamps is at the horn
but I could be wrong.
Old Jan 6, 2012 | 01:15 PM
07SSYellow's Avatar
oh, alright lol ill look there see what i find, hopefully its an easy fix
Old Jan 9, 2012 | 11:10 AM
Gremlin85's Avatar
Any luck?
dennis69
Oct 20, 2015 04:49 PM
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
