Found strange oil leak
So I have had a slow oil leak that has been getting worse the past week and could not find out where it was coming from to save my life. Finally saw oil leaking from the inside of the oil pressure switch plug. 18 bucks later for a new one and chaned my oil.....no more leak. Its located right under the oil filter in case you run into the same problem.
