frickin CEL
Old Oct 29, 2006 | 06:40 AM
picmahweji's Avatar
frickin CEL
so i purchased the injen CAI for the ss/sc...had it installed and love it..next day..CEL.....(check engine light) unplugged the battery and had the ecu restart and it was gone...next day,....CEL ...we get a code reader..identifies it as 171 meaning my engine is running too lean...more air thatn the fuel ratio can handle..so i leave my battery unplugged overnight...give the ecu longer to restart..everything was fine..until....CEl so now i dont know what to do ive tried every trick in the books....and on the forums...grr
Old Oct 29, 2006 | 06:51 AM
That Cobalt LT Guy's Avatar
Check the intake for leaks that would cause a cel.
Dead Zen's Avatar
dude that sucks and is kinda odd. I put my injen on like 8 months ago and have NEVER had a CEL. is it possible u forgot to hook up something or maybe got finger prints all over the M.A.S. ??
Old Oct 29, 2006 | 06:54 AM
bavoose's Avatar
is yours an 05 or a 06 because i had the same problem with my 05 and took it into the dealer they scanned the new code and it has not come up since but i also have stage 2 so i was pretty much flashed twice now so dont expect any codes but the 05 code should do the trick.
If there is even a small gap on the intake at the filter or TB it will make a cel. worth a shot
Old Oct 29, 2006 | 06:55 AM
2006ArrivalBlueSS's Avatar
My friend, you're not the first, and by far, won't ever be the last, to get the legendary P0171 DTC because of an aftermarket CAI. Give the MAF some time to adjust to the increased air volume and the CEL's will eventually be less in frequency and over a period of about 6 months will evenutally disappear. In the meantime, performance should not be affected with the CEL on...also, it wouldn't be a bad idea to invest into some type of scanner if you plan to further modify the car
Old Oct 29, 2006 | 07:00 AM
Dead Zen's Avatar
Forgot to mention after i installed my Injen and hooked the battery back up i let the car idle for about 20 minutes to get used to its new found breath. I also just read you said u "Had it installed", meaning u didnt do it?? I dont let anyone touch my car but me cause i believe that is why stuff like this happens.
Old Oct 29, 2006 | 02:16 PM
picmahweji's Avatar
so when u say give it time.... to adjust..do u mean just keep driving with the cel on..or keep using my buddies code reader to delete it and keep doign that till it gets used to it?...cause i can do that..its not that annoying...but it did ruin my night..thanx for the quick repsonse and help guys....and for the message below me..when i said i had it installed it was me and my two best friends..so the trust was there..especialyl with me sitting there watchin them... and helping out lol
Old Oct 29, 2006 | 02:23 PM
2K5SS/SC?'s Avatar
Your Injen should not give you a CEL. If so, you have installed it wrong, and you need to check all your work. Are you sure you put the MAF in correctly, are all your clamps tight, and did you check to see if the filter got oil in you MAF? I used an AEM dryflow filter so I didn't get oil in the MAF.
Old Nov 1, 2006 | 03:02 PM
NO. 27 SS's Avatar
the aem dry flow is the way to go, i had a oil filter on other car and put a catch can on it and you would be surprised as to the crap those filters put out. If you have anything on your mas you will throw a code..
Old Nov 1, 2006 | 03:12 PM
distillion's Avatar
AEM dryflwo sucked on my car,
water gets in there much easier due to the non oil based filter and material, when it rained i was screwed and the car ran like shat, granted i ahve the jbp intake for now, swtiched over to the filter provided and no problems since.
turbochargedss2012
Sep 20, 2023 12:17 PM
Cobalt08LS
Jun 19, 2016 07:29 PM
Dustin24
47
Feb 12, 2016 04:10 PM
DocSvensk
Sep 27, 2015 02:24 PM
jcarroll53
Sep 24, 2015 07:43 PM
