Frozen display on dash
Old Dec 29, 2014 | 03:25 AM
2009 cobalt ss's Avatar
So I wanted to check the outside temperature. It would not move,the display just reads the trip, it will not cycle thru the reading like oil % or tire pressure. Tried hitting the info button a number of times still frozen. Turned the car off and came back an hour later same thing .
Ideas?
09 TC/SS
Old Dec 29, 2014 | 04:34 AM
umrdyldo's Avatar
Buttons on steering wheel are dead
Old Dec 29, 2014 | 06:07 AM
Mr.Tozzi's Avatar
it's so cold out that the display froze to death.
Old Dec 29, 2014 | 06:55 AM
Xmetalhead2003X's Avatar
I have a set of buttons for an 08 tc. Pm me with a price.
Old Dec 29, 2014 | 07:49 AM
umrdyldo's Avatar
I have never seen how those buttons come off. Anyone posted pictures?
Old Dec 29, 2014 | 08:04 AM
ATOMbomb's Avatar
Pretty sure you have to take the air bag out to get to them. Atleast that's how it is if you want to paint the trim on the steering wheel.
Old Dec 29, 2014 | 04:41 PM
^ this. I replaced my wheel. They have to be removed with the wheel off for the easiest way.
Old Dec 29, 2014 | 04:50 PM
This happens to a lot of cars not just cobalt's
Old Dec 30, 2014 | 05:06 AM
The other buttons work like volume& mute .The cruise control lights up. I live in Laguna Beach, CA it gets maybe 50degrees at night. I got it to cycle once today. Then it froze again. At least it's stuck on mileage and outside temp. Traction control works too. Love Competition mode on PCH
Old Dec 30, 2014 | 07:15 AM
I wonder if there might be some pinched wires, or if the clock spring might be going bad. I know that'd give you an airbag light, but the wiring goes through that part. These buttons can be taken apart to clean out, you just have to be careful with them when you're removing them down to the circuit board.
Old Dec 30, 2014 | 12:29 PM
rains_crusader's Avatar
The radio controls are on a different circuit as are the cruise buttons and DIC buttons. Try a new switch first or clean your old one. You can remove them by releasing the airbag from the steering wheel. You don't necessarily need to disconnect the bag to do this. Just be careful not to pull or stress the air bag connector wires much. Just release the air bag clips and move the bag to he side a little. You'll have enough room to get to the star bolt holding the bezel in place.
Old Dec 30, 2014 | 12:34 PM
Well i have a similar problem to that if my rpd doesnt turn on my steering wheel controls wont work. You should check some fuses thats my problem if i touch the fuses the rpd works and everything starts working.
riceburner
Sep 30, 2015 03:54 PM
xxenjoi11
Sep 29, 2015 12:36 PM
Cptnslo
Sep 24, 2015 09:32 AM
Cptnslo
23
Sep 15, 2015 10:53 PM
ATOMbomb
Sep 11, 2015 10:48 AM
