Frozen Door Hinge?
Old Dec 16, 2008 | 11:05 PM
LAW-BALT's Avatar
Frozen Door Hinge?
Now that the temps here in WYO have been sub zero for several days, my driver side door is making a horrible noise when opened and closed. Any thoughts? Since reading the thread, I've noticed that the paint is rubbing off at the bottom of the door but I don't think it's connected. This sound is terrible!
Old Dec 18, 2008 | 12:29 AM
zay52790's Avatar
i would actually guess that the sound is the bottom of the door rubbing against the rest of the body when you open it
Old Dec 18, 2008 | 12:34 AM
deuce's Avatar
paint rubbing off is a common problem with the balts
Old Dec 18, 2008 | 01:46 AM
LAW-BALT's Avatar
The paint rubbing off sucks. It sucks because I can't think of a way that the dealer could actually resolve the problem, but the noise I'm hearing is definately coming from inside the fender where the connecting rod (half way between the henges) goes into the fender. My guess/hope is that a little moisture got into the fender somehow and is now frozen and restricting movement but it sure sounds like metal-on-metal. Just wondering if anyone else had encountered this? Hoping this will go away and stay gone when things thaw.
Old Dec 18, 2008 | 02:53 AM
Ducky22287's Avatar
I hear the same thing sometimes opening the trunk. Does it do it everytime, or just when u first open the door in the cold?
Old Dec 18, 2008 | 09:50 PM
LAW-BALT's Avatar
Does it when opened and closed. Things thawed today and it has stopped.
Old Dec 18, 2008 | 09:56 PM
JimzSS's Avatar
Good and now your sub freezing temps are headed our way...lol
Old Dec 18, 2008 | 09:58 PM
boostedss26's Avatar
It could be the check strap. As for the correct way to fix the paint is. this is what i did. Repaint the door jamb and i put some 3m chip guard clear tape on the bottom where the seal meets. It's been 2 years and it's still perfect.
Old Dec 18, 2008 | 11:15 PM
LAW-BALT's Avatar
Check strap?
As for the paint (probably a remark for the sticky thread) I guess the dealer could re-hang and adjust the door; but I'm thinking that weight is causing the problem so your solution is a good one- thanks! I had similar issues with a sagging door on my first car, an '84 Monte Carlo SS.
You guys in the midwest are welcome to this frigid weather!
Old Dec 19, 2008 | 08:06 AM
Originally Posted by LAW-BALT
Check strap?
Do you know what the check strap is? it's the black part between the two hinges that keeps your door from closeing on you when you open it, they go out often. And as for the cold is -14 here this mornin
Old Dec 19, 2008 | 08:11 AM
Jackalope's Avatar
GEEEEZ! This is an EASY fix guys!
Any questions?
satisfied
Oct 19, 2015 12:35 AM
dasoftest
Sep 29, 2015 02:14 PM
xxenjoi11
Sep 29, 2015 12:36 PM
royce777
Sep 28, 2015 07:11 AM
dieGone
Sep 23, 2015 10:20 AM
