fuse help!!!
Old Mar 14, 2009 | 10:38 PM
SlowBalt_06's Avatar
fuse help!!!
i was installing my halos and i think i popped the fuse for the parking brake lights and whatnot...where is it i cant find it under the fuse box?
Old Mar 14, 2009 | 10:40 PM
boostedss26's Avatar
Look in your manual if you have it
Old Mar 14, 2009 | 10:41 PM
BLAZIN07SS's Avatar
I'm too JDM for you
its in the fuse box under the hood. its the one almost in the middle i believe. it should be a 20amp fuse
Old Mar 15, 2009 | 12:44 AM
Erod's Avatar
Moderator Alumni
post in correct section. moved
Old Mar 15, 2009 | 10:52 AM
Coblasts's Avatar
Parking lights
Under the hood
Park Lps fuse 15 amps
Brake lights
Fuse 9 10 amps
Stop Lp on the BCM module
Headlights
There are 4 fuses under the hood
all 10 amp
RH HI, RH Low ,LH Hi,LH Low
WhineSSbaby
Sep 1, 2020 12:39 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
jmelton327
Sep 26, 2015 10:04 PM
brickloaf
Sep 25, 2015 09:10 PM
shawnsseries
Sep 10, 2015 08:29 PM
