Gauges Droping????
Old Mar 22, 2008 | 09:35 PM
Sta-meng's Avatar
Exclamation Gauges Droping????
So when i ever i get in my car and drive it around for like 1 mile, all my gauges turn off(not the boost ) and it flashes power seering, then it flashes low fuel. and Yes theres fuel in it. It happens alot. Im getting pissed because ill take a girl out and my gauges just stop working. They come back after about 30 secs.
some one plz help.
Old Mar 22, 2008 | 09:47 PM
hungryhip-ccp's Avatar
go to the dealer not normal
Old Mar 22, 2008 | 09:56 PM
golden chicken's Avatar
did you recently...or ever...jump start the car?
Old Mar 22, 2008 | 10:05 PM
SlowBalt_06's Avatar
nope my car does the same thing...its been to the dealer 8+ times no fix...it pisses me off and i'm considering the lemon law
Old Mar 22, 2008 | 10:46 PM
Ducky22287's Avatar
Claim that's it's dangerous cause you can't see your speed or rpms (play it up a bit lol).
Old Mar 23, 2008 | 03:04 AM
no my power steering actually shuts off and i'm worried with the other problems if i get in to a wreck my air bags wont go off
Old Mar 23, 2008 | 03:07 AM
halfj99's Avatar
definetly not something you should be messing with with a car under warenty...they need to fix that or get you into a safe car...thats unacceptable
Old Mar 23, 2008 | 03:08 AM
my car only has 17,xxx on it
Old Mar 23, 2008 | 03:16 AM
USMCFieldMP's Avatar
Rattlesnake Race Shop
My car did this for like a month. I scheduled a trip to the dealership for the next week. It didn't do it at all that week and hasn't done it since.
The dealer at the time of scheduling suggested that it might be something with the Passkey... or some **** that is in the actual turn key part of the ignition. I dunno.
All I know is that I played around with the ECU and pushed on the connectors and it hasn't done it since.
it IS scary and frustrating when it does it though.
Old Mar 23, 2008 | 08:06 AM
Ducky22287's Avatar
You should take care of that soon. I'm pretty sure that the law in NY is 18k miles or under for lemon law to work so definatly check your state.
Old Mar 23, 2008 | 09:25 AM
Coblasts's Avatar
Check your run crank relay in the fuse box under the hood.
Make sure it is seated properly. Pull it out and inspect the legs on the relay for burning hot spots anything that looks like it was arcing.
This relay feed all the stuff you were talking about.
from there it goes to the bcm check for a loose connection on the fuse box connectors as well.
Also check the fuses that they are not lose or not seated properly.
These symptoms you describe is normally cause by a heated connection or component because when it cools down it comes back on,
My guess though will be the BCM module ,but you cant check it.
Old Mar 23, 2008 | 03:23 PM
tastes sour to me
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
z28addiction
Sep 28, 2015 12:03 AM
Sep 27, 2015 08:53 PM
