GM caliper service
Old Nov 21, 2007 | 01:50 PM
StoryoftheYear's Avatar
GM caliper service
a tech at the dealer recommended it and said it would extend the life of my brakes.....is it worth it? i think its around 60$?
Old Nov 21, 2007 | 01:54 PM
SSdan's Avatar
How many miles? Probably not worth it and just another way to get money from you.
Old Nov 21, 2007 | 02:15 PM
hmmm thats what i was thinkin..anyone else?
alleycat58's Avatar
What exactly is the caliper service? Assuming a front rebuild? If so, you can do that yourself, the kits will cost you $20+tax and about an hour and a half total.
Rears, they aren't rebuildable AFAIK. Then again they could just be doing a lube and cleaning. If that's the case you better hope they're lubinb cause they sure aren't cleaning, if you know what I mean....
Old Nov 22, 2007 | 09:47 AM
Coblasts's Avatar
They will probably take your wheels off and relube the pins and contat point on the caliper so that it doesnt seize.
This is something I would do in the spring ,But I do it myself.
Ever do a brake job and wonder why one pad is wore(same side) way thinner than the other .Pins should have been lubed.
Old Nov 23, 2007 | 04:55 PM
MTPockets's Avatar
That's exactly what this service is; Releasing the calipers & popping the pads out so the slides can be cleaned, lubed and the pins can be checked for lube and a good boot seal. Easy DIY, but is nearly as time consuming as changing the pads. This service will definitely extend the life of your brakes if you live in the rust belt.
Old Nov 23, 2007 | 04:57 PM
joeworkstoohard's Avatar
sounds like a bit to me... but then again, if you're one of those people that is scared of brakes...
Old Nov 23, 2007 | 04:58 PM
M-Dub's Avatar
It is completely unnecessary unless you have lots of milage!
Old Nov 23, 2007 | 05:27 PM
alleycat58's Avatar
As someone who started with serious brake issues at 20k.......it's not just a high mileage thing. Regular maintenance type thing yes, but it should be done EVERY brake change at an absolute minimum. More often if you live in the rust belt like someone else said.
patooyee
Oct 15, 2015 05:11 PM
DANRICKARD
Oct 1, 2015 12:08 AM
importkiller
Sep 30, 2015 07:18 PM
grampss
Sep 27, 2015 08:51 PM
QuickSilver_SS
Sep 17, 2015 05:38 PM
