Grinding issue
Old May 4, 2011 | 09:58 PM
C_A_D88's Avatar
Grinding issue
So yet another one
So I recently just lowered my car on ark stp coilovers
I don't know if this has anything to do with the coilover installation but I figured I'd ask here before I try and throw my tc shocks and struts back in to see if it solves the issue
I've never had a lowered car before so I don't know if it's just rubbing I hear or not, doesn't sound like rubbing and it doesn't look
Like it could be rubbing anywhere
But I made a sharp left hand turn ( steering wheel all the way to the left) and herd/felt a grinding that got worse with an increase in speed, tried to see if it would do it doing a sharp right hand turn and got nothing.
But I think it sounds and feels fine driving normally, could it be my bearing? And I've just gotten used to the sound at normal driving? Or what else could it be?
Old May 4, 2011 | 10:01 PM
Chevycobaltss3's Avatar
Could be bearing or ure axel rubbing depending on how low u went. Lol.. And yes it can happen
Old May 4, 2011 | 10:07 PM
C_A_D88's Avatar
I'm sitting at 24.5 inches from the ground to the top of the fender on the fronts and 25 in the rear
Old May 4, 2011 | 10:43 PM
C_A_D88's Avatar
If it is axel bind, anyway to fix that while stAying at my current height?
Old May 4, 2011 | 10:44 PM
U would need to grind down control arm.. I say ure issue is bearing.... . only way to tell is tske front tires off and.look
Old May 4, 2011 | 10:47 PM
LS6Rally's Avatar
^ youre not going to see a bad bearing on these cars with the wheel off. i dont see it being a bearing, you would still hear it going in a straight line.
while turning, hit the brakes, does th enoise go away? if so see if you bent a backing plate while you were in there. how loud it the grinding?
Old May 4, 2011 | 10:56 PM
C_A_D88's Avatar
grinding gets louder and very noticeable with a lil bit of speed, and what do u mean by bent a backing plate?
Old May 4, 2011 | 11:01 PM
lmfao alot.. I know this but u can inspect wobble and play... Im vry knoledgable.. And i can see it being a bearing. . Take the wheel off and inspect...................
/B]
Old May 4, 2011 | 11:07 PM
LS6Rally's Avatar
you check wobble and play with the wheel on. no need to remove the wheel.
Old May 4, 2011 | 11:13 PM
C_A_D88's Avatar
I've done this last week but found no wobbly or play in the wheel, will check again tomorrow tho
Old May 4, 2011 | 11:21 PM
U can check it on or off bro. There is a reason for the wheel to be off lol.. U can also inspect everything else while in there. Yeah u can check wobble and ect with the wheel on.. Lol...
/B]ffw
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
